Troubleshooting & Support
Hot Topics:
- water line...
- jcd2389des
- not making
- ICE MAKER...
- jcd2389de
- defrost water...
- Frost
- turn off
- dispenser
- new
- water
- leak
- making
- ice maker leak
- hollow
- turn
- ice maker not...
- water dispenser
- bottom
- solenoid valve
- aire
- thermostat
- cycle
- noise
- icemaker
- stopped working
- stopped making
- setting...
- hollow ice
- ice maker
- View All »
Problems & Solutions
no water flow to ice maker in 18 cu ft GE
Change filter and clean out lines.
Not making ice
replace the water vavle.
I have a Jenn-Air Refig with the freezer on the
Make sure you remove all of the ice from the fill tube! It goes back a good 10 inches! To remove ice from tube, make sure you remove the ice...
No water flowing to ice maker
to see if icemaker is still good pour a 1/2 cup of water into tray and wait for a day. make sure shutoff arm or switch is on or down (arm...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if...
just installed refrigerator. how long does it take
The icemaker has a thermostat built-in that calls for water from the water valve at a certain temperature. Ideally, the freezer temperature...
Water not going into tray
BET THE WATER HISE IS FROZEN. TRY A HAIR DRIER TO MELT THE ICE IN THE HOSE.
The ice maker suddenly stopped making ice. The
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker...
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve...
Icemaker Waterline has Bacteria in it
This bacteria (for most of us) is not harmful. Ive never heard of anyone becoming sick from this stuff but I suppose someone might have an...
Locked freezer
Press and hold the lock button for at least 3 seconds
Jen aire ice maker not working
change filter and defrost water lines if frozen
ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
the ice maker won't stop
Hi slh3095, The easiest way to stop the ice maker in making ice is by raising the shut off arm. Please check if the shut off arm can move...
my jenn air ice maker is not filling up the water
Change filter and clean out lines..... download the service manual...
See all Jenn-Air Freezer Jenn Air Clear Cube Ice Maker Solutions
Unsolved Problems
Jenn Air Icemaker Shut Off arm
I just put in a new Jenn Air icemaker. It makes ice, but each time it dumps a new tray of ice, the shut off arm goes...
how do you disconect the wireing on a jenair
how do you disconect the wireing on a jenair icemaker
Ice maker resevoir fills &spills
Ice maker resevoir fills &spills over to make an Ice cisicle
i replaced the valve at
i replaced the valve at the back of the fridge. I have water going to the fridge but can see that the water is not...
jen air side by side
jen air side by side is leaking is leaking inside on the bottom of the ice bin. Water is dripping down the inside of...
motor not turning to dispence
motor not turning to dispence ice throgh door
jemm air jcb2058geb won't make
jemm air jcb2058geb won't make ice, ice maker works, how do you test primary/secondary valve, hose lines?
jenn air ice maker making
jenn air ice maker making cubes but after falling into catcher tray they all melt! we have checked the board temp...
My undercounter Jennair water tank won't empty
My undercounter Jennair water tank won't empty after running the cleaning cycle
See all Jenn-Air Freezer Jenn Air Clear Cube Ice Maker Problems
Upload a manual for Jenn-Air Freezer Jenn Air Clear Cube Ice Maker
What's your problem?
Fix-O-Meter
12,979
12,979 people have viewed this product
- 107 people asked about this product.
- 36 people found solutions for this product.
- 1 person has added this product.
Making more...
How to Defrost...
How to Repair a...
