Dear ,First you have to remove all old installed driver of this p'rin'ter along with Paper Port also, Do not connect the printer to PC before it is asked to do So, Now installed the New Driver again , When PC shows PLUG IN THE USB CABLE than connect the machine with PC, It shows NEW HARDWARE FOUND , and then it will complate the installation,
its most prob a driver problem, thats the trouble with vista if you have installed the cd driver disk that came with it,
its most prob only for xp it will run on vista but not all features will work go to hp web page click on the drivers and software location, then put in model number of printer then next it will give you diff. windows drivers and pick the vista one that with your pc/laptop but please un-install the software you are using first the shut down and restart..
then install the new drivers etc this should sort out your problem.
if still having problems please get back to me .. matdav69
All that you need for that printer. Just select your OS and download the drivers
Or click here: mp460vst110bea23.exe
The drivers is for XP/VISTA/2000, they all use same drivers
Good luck
Nic
Download The PS driver from hp.com.. u might be using a PCL 6 driver.
Got to www.hp.com
Click on support & drivers.
Select Download drivers & software
enter ur product.
Select the OS on ur comp.
Download PS driver & install it.
use the product finder to select your exact model and operating system. download the file and save to your desktop. after download is complete, close all browser windows and run the install program. This will properly install the correct driver for you.
Don't worrly Fixya will help you in findding the setup disc very easily... To download the drivers, Please click on the below link or copy the URL and paste it in your web browser.. And Select DRIVERS, and select the operating system you are using and download the drivers.. http://www.brother-usa.com/downloads/Default.aspx
Thank you......
the settings should still be installed on your comp acces controll panel and select printer and faxes this should give you a list of printers yours should be in this list if not have you still got disk if you havent the you could access controll paned and select hardware devices and make sure printer is plugged in then let your comp search for new devices when its finished select the printer from the list if you dont have disk it will ask if you have it select no then the comp will serarch for the setting for you but it should still be installed on your comp anyway. have you tried just plugging it in and trying it to see if it works cus your comp might just set itself up any way i hope this is some help to you
