Try this take an old empty cartridge and mix some ink cleaning fluid into each of the tanks. Now take some alcohol and a Q--tip and wipe the heads on the contacts where the cartridge comes in contact with the printer head.
There are three contacts that control color and one that controls the black . Clean with the alcohol, wipe with a Kleenex or a dry q-tip lightly. Now lightly shake the used printerhead to mix the cleaner into the residual ink that remains in the Printer cartridge. Now once the the cartridge has bee reinstalled in your printer go through a printerhead cleaning and head alignment evolution. Instructions for this should be in your printer manual which is a drop down program on the Printer Program Main File Icon. Some printers will automatically set up this program on the screen in easy to follow steps. If this doesn't work its time to get a new printer , add it to your Christmas list.
SOURCE: more than "one ink catridge installed" problem with new printer
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
SOURCE: Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
SOURCE: Printer Canon Pixma MP750 won't let me use just black ink
you cant print without color cartridge
SOURCE: when printing colored picture the yellow color is not working
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
SOURCE: Changing print color cartridge
The cartridge you have change are did not much or not compatible with your printer. You just buy a cartridge with the same brand of your previous cartridge that used and to make sure that your printer are recognize it. Because some compatible ink are cannot be recognized by other printer.
