Ricoh Aficio CL2000N Laser Printer Logo
Posted on Mar 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ricoh Aficio CL2000N is printing several faint lines
My Ricoh Aficio CL2000N is printing several faint, black vertical lines - one about 1/2 inch from the right, another about 3 inches from the right, and one about an inch from the left. It also periodically prints a thin, fuzzy, horizontal line about 1/2 inch in length extending from the left edge of the paper. Any thoughts?
  • Anonymous Mar 13, 2014
    horizontal lines print every 3 inches
Anonymous
Level 2:
Sniper:
  • Expert 58 Answers
  • Posted on Apr 06, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
58
Questions
0
Helped
64054
Points
131
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
3helpful
2answers
Three small white vertical lines in black printwhere the black does not print. Not present in other colors.
This is coming from the Black Drum Unit. You may be able to remove the unit and look into the slot on the top. You should see the drum which is green in color and may be able to see the lines. Not much you can do with these units so you may just have to replace it.
2helpful
Where is the black photo condutor on Richo Aficio CL200N located?
I found the manual for your laser printer courtesy of Ricoh:
http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf
Page 5 of the PDF manual talks about the black photo conductor and where its located at.
3answers
Thin lines along left side of Ricoh CL2000N laser printer
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Ricoh CL2000n Black photoconductor
make sure you have all the packing off the photo conductor. and make sure the track is damaged
1helpful
2answers
You may have to replace the transfer belt or the drum. I would start with the drum first
http://www.websitetoolbox.com/mb/copierquestions
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
2answers
Faint Black Lines
Hi best way to check is to remove the black photoconductor and you should be able to see the little lines on it also check the the black dev/toner unit for the lines. most likely to be the black photoconductor unit though.
Thanks J
Black lines (streaks) printing on left of page on my ricoh 2000n
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
