I beliwe I allready answered that question too, a while ago,but anyway...You has to clean plattenglass,optical system and mirrors.How many copies did drum made? If more than 100000 you'll probably got to change it
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
E065 if you already change primary corona assy and the problem is the relay pcb , you can found it in the lower left side of the machine, i encountered it twice check if the fusible resistor is busted , if faulty u can jumper it using wire.
#pw+191714113014151+1# #pw+791380315060724+2# #pw+143594461252033+3# #pw+728060340707705+4# #pw+891581411072520+5# #pw+782330602170276+6# #pw+004983726336520+7# these are the unlock codes dial this codes
Tell Vodafone that you want to change to O2. If your phone as it is will take O2 you will have no trouble. otherwise you will have to find a phone shop that will open the phone to all networks.
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Désolé car j'ai le méme problème et je trouve pas de solutions, un code d'erreur E065 puis ca bloc avec un bourage, c'ent ambétant car ca me fait perdre beaucoups de papier. merci de m'aider
