This maybe the spring in the door has fallen off is the latch head very loose in the door if it is it maybe the hook on the bottom of the latch head has broken off, to get to the latch you need to pry the inner door trim off as u do this you will need to lift the the latch head up the trim is only cliped in so if you start in between the 2 hooks of the latch then work your way round the door you should be ok when you are inside the latch then have a look and see if the spring is still in place and not fallen off or loose if it has fallen off look at the bottom of the latch you should see a small hook at the end if this is miss then you need the latch please unplug the unit before you undertake any work on an appliance hope this helps
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
If the microwave door won't open the button might be broken internally. The button can be replaced.
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
