20 Most Recent Panasonic Nn-Sf460m 27 Litre Flatbed Microwave Oven In Silver Questions & Answers
SE985S Panasonic genius plus microwave keeps blowing 20a fuse on average about once a year. Everything works fine for another year after i replace the fuse.
Are other appliances running on the same circuit? Does it happen in the summer with the A/C on? It may be starved for voltage. I've seen this happen on homes where the beaker panel is undersized or has a loose connection.
1/29/2023 11:16:52 PM • Panasonic... • Answered on Jan 29, 2023
When i press it display error in panasonic dimension 4 genuis model nn-c897wbbpq
An "error" message on a Panasonic Dimension 4 Genius model NN-C897WBBPQ microwave oven could indicate a problem with the electronic control system. It is recommend to try resetting the microwave by unplugging it for a few minutes, then plugging it back in. If the problem persists, you should have the microwave checked by a professional technician. You can also try to reset the oven by following the steps in the user manual, which typically involves pressing a certain combination of buttons on the control panel. If the problem is still there, it is advisable to contact the manufacturer or a professional technician for repair. This will help you to get a more accurate diagnosis and a solution to the problem. Depending on the cause of the issue, the cost of repair can vary. It is important to note that, error messages can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
1/18/2023 6:46:03 AM • Panasonic... • Answered on Jan 18, 2023
Repaired latch inside door, but when I close the door the light stays on and reads close door
Repaired latch inside door, but when I close the door the light stays on and reads close door How To Fix A Stuck Latch If your door can open correctly but can't close without getting stuck, it's likely an issue with the latch. Multiple issues can compromise door latches, such as a mechanical error, worn down latch components, broken door handle cables, and more. If the latch is simply stuck, you should be able to fix this yourself without taking your car to a mechanic. Just take some oil lubricant, like WD-40, and spread/spray it into the latch mechanism of your open door. Let the oil soak in for a little bit, then use a microfiber cloth to rub the oil into any visible parts of the latch. While performing this task, check to see if you can find any rust on latch components. If you do, use a piece of steel wool to scrape the rust away. Once removed, try opening the latch with your door handle to confirm that it is once again functioning correctly. In some situations, your latch may accidentally be closed when it should be open. This can happen for multiple reasons - sometimes due to an electrical glitch or a mistake made while repairing the door. Either way, if you have a car door with a closed latch, try opening your door and looking at the latch to determine its orientation. Then, open a functional door and look at the latch to see how it's supposed to be. A working door will have a latch with "open" jaws. These jaws can catch the door jamb anchor and rotate into a closed orientation to secure the door. If the latch's jaws are already closed, it can't engage with the anchor or close properly. To fix this issue, take a screwdriver and hold the door handle in the open position (pulling if necessary). As you pull the handle, rotate the latch with your screwdriver into the correct orientation. If needed, ask a friend or family member to help you hold the door or hold the handle open for you while you perform this action. Once you have moved the latch into the correct orientation, test the door handle a few times. The latch should open when you pull the door handle, and the door should again be functioning correctly.
1/16/2023 7:33:28 PM • Panasonic... • Answered on Jan 16, 2023
2answers
Panasonic Microwave Continuous P-Countdown
A P-error-countdown on a Panasonic Genius microwave can be caused by a number of issues. First, try unplugging the microwave for a few minutes and then plugging it back in. This can often clear any temporary error codes and restore the microwave to normal operation. If the problem persists, check to make sure the door is closing properly and securely. A damaged or misaligned door can cause the microwave to think that it is open and prevent it from working. The issue could also be caused by a problem with the microwave's control panel. Try to reset the microwave by unplugging it for a few minutes and then plugging it back in. If the issue continues, it is likely that there is a malfunction with the microwave's control board or other internal component. It's best to contact the manufacturer for assistance or take it to an authorized service center for repair. It's important to never try to repair a microwave oven by yourself as it can be dangerous and may cause damage to the appliance or even injury.
1/14/2023 3:59:54 PM • Panasonic... • Answered on Jan 14, 2023
Countdown through oven's Power Levels
Check that particular outlet for a neutral ground
1/14/2023 3:22:23 PM • Panasonic... • Answered on Jan 14, 2023
How do i mute a panasonic NN-ST67JS microwave
I don't think you can. I see no sound button. Nor is there a code in the user manual suggesting such. At the bottom of page 12 in the user manual, there is a short description of what all the beeping is about. When a pad is pressed correctly, a beep sound will be heard. If a pad is pressed and no beep is heard, the unit does not or cannot accept the instruction. The oven will beep twice between programmed stages. At the end of any complete programme, the oven will beep ?ve times. I don't think you will find the answer in the following: https://soundproofnation.com/how-to-mute-microwave/ Some microwaves have a sound button. Others may off the sound by pressing 0 or 1 a couple of times. Some have controls that put on a child lock, making the pad inaccessible, thus no beeps! If is another way to mute the sound in yours, a Panasonic tech would have to tell you. You might try their support. I just don't think there is that opton in your machine. https://www.manua.ls/panasonic/inverter-nn-st67js/manual?p=12 https://na.panasonic.com/us/support
1/14/2023 3:02:15 AM • Panasonic... • Answered on Jan 14, 2023
How to fix the display lights from going off when I close the door?
do mean the LCD or plastma graphic display goes 100% deadwhen door is closed, and not coolingmine shows TIME there, page 12 in your manualunplug Uwave from AC wall jack for say 30 minutesplug back in and he display asks for time, it must and was lost above.myGE WILL NEVER WORKs If TIME AND AM/PM ARE NOT SET first.THIS UWAVE HAS CHILD LOCK FEATURES. and more oddities,HERE IS THE FREE MANUALhttps://www.manualsdir.com/manuals/453553/panasonic-nn-sn797s.html?page=12AND PAGE 13 ALL OFF THAT page (settings)it EVEN sets CLOCK OFF odd demo modes and more, read it all.IF KIDS PLAYed HERE, THERE ARE MANY THINGS THERE TO GET WRONG ,SO PULL THE AC CORD, FOR 1HR OR MORE. IF IT FAILS TO RESET, LIKE PULL ac CORD OVERNIGHT,.gOOD LUCK. (yes way over too complex)
8/21/2022 6:39:34 PM • Panasonic... • Answered on Aug 21, 2022
Panasonic Microwave NN-SN966S Keypad Stopped Working
well , one can work sans sCHEMATIC BUT that is no fun. my GE the top casing, day 1new had that there taped up there. LCD Ok? wow youtube can get in in trouble fast what in the world is a chip belt.???????? the top failers are in order is this (not carousel motor dead) 1; the 4 safety interlock switches are bad. I'm on set #4 now. 17 years old GE and runs like a champ.. 2: maggy dead. or the cap to it or the diode to it dead HV-DC lethal. 3: the overheat sensor bad. 4: the humidity sensors bad (too much steam from food) 5: main fuse blown due to #1 failure and by DESIGN. I bet Panasonic refuses to sell you the service manual right? 6: rare but if hit by lightning the main logic board is bad. your users manual has no schematic like my GE has. now more on #1 the 4 switches timed super carefully and if off time just a tiny bet the Uwave fails hard this protections prevents say Uwave RV burns to the retina.s an blindness, so is not some game here it is serious. why not get a real tech to fix and for sure never defeat any switch here or touch the 2000vdc cap there. lethal. yes it is double lethal device is blind considered.
8/21/2022 6:30:02 PM • Panasonic... • Answered on Aug 21, 2022
Where in Canada BC I can buy Magetron for my Panasonic Microwave Madam Grill NN-8858?
The part number of the magnetron is on the magnetron label. Beware, Lethal voltages are within microwave ovens. Be warned!
6/30/2022 7:04:01 AM • Panasonic... • Answered on Jun 30, 2022
Microwave 8888 inPanasonic
Set the clock.
5/30/2022 7:03:13 AM • Panasonic... • Answered on May 30, 2022
2answers
Where can I purchase a new touch pad for a Panasonic model NN-S254WF microwave
Try espares.com or any Panasonic domestic appliance service centre
3/31/2022 5:59:06 PM • Panasonic... • Answered on Mar 31, 2022
Can the screen brightness on a Panasonic NN-SU66LS microwave be lowered?
No, but you could cover is with a smoked plastic film like car window tint.
3/3/2022 5:58:43 AM • Panasonic... • Answered on Mar 03, 2022
My Panasonic Microwave (NN-CF778s) locked itself with Error code H98.
You cannot repair this yourself, replace it. google Panasonic nn-cf7788s error code h98 for more info.
11/30/2021 4:20:09 PM • Panasonic... • Answered on Nov 30, 2021
I would like a free manual for my Panasonic Dimension 4 Turbo back microwave oven
I found a manual for the Panasonic Dimension4 NN-C988W convection microwave at ManualsLib: https://www.manualslib.com/manual/652153/Panasonic-Dimension4-Nn-C988w.html . I hope this helps. Cindy Wells
11/10/2021 12:57:54 AM • Panasonic... • Answered on Nov 10, 2021
Panasonic over the stove microwave...door wont open
https://www.youtube.com/watch?v=xne8GQ1n5Yw
11/2/2021 10:03:45 PM • Panasonic... • Answered on Nov 02, 2021
Panasonic Nn-Sf460m 27 Litre Flatbed Microwave Oven In Silver Logo
2 questions posted
Top Panasonic Microwave Ovens Experts
Jaime Hernandez
Paul Bade
Steve
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Microwave Ovens
Most Popular Question
panasonic nn sf460m inverter 900w
  • Microwave Ovens
