My samsung over the range microwave door will not latch.
You will need a Samsung dealer repairman, the inner mechanism will need to be serviced because for some reason it is jammed or there are broken parts.
Wow I took this door apart and was disappointed to see how the door latch spring bracket was so thin and poorly designed that it was doomed to fail. Shame on you Samsung for engineering so poorly just to guarantee the need for service calls. I simply drilled another hole in the door latch bracket at a thicker part of the plastic and attached the spring to that. Finished the repair in 5 minutes without ordering any parts.
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
SOURCE: door latch on sharp 1480 microwave over the range oven
door panel.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Normally
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
door panel.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally
you have to separate the door panels (as shown in the manual)
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
If the microwave door won't open the button might be broken internally. The button can be replaced.
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
My microwave wasn't latching totally and would turn on and off. I found that the plastic latch that hold the lower part of the sping in place broke off. I glued the lower latch back on and that fixed the problem.
