20 Most Recent Samsung SMH9187ST Microwave Oven Questions & Answers
How to replace humidity sensor for samsung microwave oven?
I thought I needed a sensor also ( and you might), but first try this. Remove keypad. Find ribbon connector near lower edge, Gently slide a plastic ball point pen between the 2 ribbons to gently separate them. They may feel glued together. I then used a Q-Tip with a drop of alcohol to swab between the ribbons. Then cut a small piece of paper, cardboard or plastic and slide between the separated ribbons. Re-install keypad. Problem with mine was the keypad was basically shorted out. The ribbon connectors being stuck together caused multiple errors like child lock and daylight savings errors. Hope this helps someone.
11/12/2021 10:23:46 PM • Samsung... • Answered on Nov 12, 2021
6answers
My Samsung Microwave gives an error code -SE-.
Hi cbrophy91,
On Samsung microwaves the SE error code flashed on display means "Sensor Error". This means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
10/22/2019 2:03:28 PM • Samsung... • Answered on Oct 22, 2019
3answers
Samsung microwave shows SE on display
The problem lies with the mylar ribbon cable that connects the Keypad to the circuit board. The Mylar ribbon cable folds back onto itself and are touching. Over time the mylar 'breaks down' electrically and the wire traces in the mylar will 'arc' onto the other mylar ribbon cable. The solution is to separate the two mylar ribbon cables using paper and electrical tape. I've done this on several microwaves (not just Samsung) and it has worked every time. Patience and about 20 minutes is all it should take to fix it. I've described below how I did it for the SMH9187ST Microwave Good luck to all.
1. UNPLUG THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2) screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch (there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad Housing (phillips). Lift the Keypad Housing upwards about half an inch (there are tabs holding the Keypad Housing in place) and remove. Be careful of the metal grille that is just above the Keypad Housing as this may fall out since it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses that are attached to the Housing. Carefully unplug the wiring harness that has the RED connector on it from the circuit board. Carefully unplug the small white connector that has the mylar ribbon cable on it (this cable is see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit board onto the Housing.
7. The Housing should now be free of the circuit board and wiring harnesses. It's safe to let the wiring harness/circuit board hang free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing. There are (4) plastic tabs holding the frame in place. Using a small screw driver pry one side of the frame away from the housing (try to do this to the side that has smaller plastic tabs). When this side of the frame is free of the Housing you have to lift the frame out at an angle to remove. It might put up a fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the mylar ribbon cable that is coming out from underneath the Keypad assembly. You will notice that the mylar ribbon cable folds back onto itself as it re-enters the Keypad assembly. This 'touching of the two ribbon cables' is where the trouble lies. The ribbon cables may be stuck together. Carefully separate these two and then insert a small piece of paper between them (paper can be 1/2 x 1/2 ) and work the paper all the way down into the Keypad assembly as far as it will go.
10. 8. Using electrical tape, apply a small piece between the ribbon cables to hold the paper in place. Next, use more electrical tape and put it between the mylar ribbon cables enough so as to keep the ribbon cables separated.
11. 9. Re-attached the thin metal frame making sure to press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw metal edge of the thin metal frame to prevent the mylar ribbon cables from rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful when inserting the ribbon cable connector back on to the circuit board. The connector is loose and you need to gently place the ribbon cable into the circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset and ask you to set the time.
16. Hope this works for you !!
11/21/2018 10:30:58 PM • Samsung... • Answered on Nov 21, 2018
The microwave display shows
From page 23 of Service Manual, --SE-- is a membrane keypad error. Replace control panel.
12/8/2017 3:48:51 AM • Samsung... • Answered on Dec 08, 2017
Error 3 on microwave
If you wish to get some details about microwave oven repair and maintenance then check the following link http://electro-medical.blogspot.com/
8/18/2016 3:15:01 PM • Samsung... • Answered on Aug 18, 2016
We have taken it apart and tried with tape cleaned and still the same
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
8/18/2016 10:43:41 AM • Samsung... • Answered on Aug 18, 2016
Why does my Samsung microwave smh8165ste have error code --SE--?
SE indicates a shorted membrane switch on the keypad. Unplug the oven for a few minutes to see if it clears. If not, leave it unplugged overnight. If the problem persists, then you probably do have a switch that's bad. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
6/7/2016 12:29:10 PM • Samsung... • Answered on Jun 07, 2016
My samsung oven is showing se error cpde. How do i fix it?
Unplug it for a few minutes to see if that clears the code, if not, unplug it overnight. If the problem persists, then you might have a shorted membrane switch on the keypad. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
6/7/2016 12:25:33 PM • Samsung... • Answered on Jun 07, 2016
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
6/7/2016 12:23:03 PM • Samsung... • Answered on Jun 07, 2016
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
6/7/2016 12:17:40 PM • Samsung... • Answered on Jun 07, 2016
Beeping sound with SE or 5e code
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad. For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm See my profile picture if you need more help.
5/23/2016 6:49:59 PM • Samsung... • Answered on May 23, 2016
How do I get the door off
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove. Or you can watch a YouTube video (not a video I made) that demonstrates how it's done. In some cases, you then have to gently rotate the handle to unlock it. You can find helpful exploded view diagrams and order parts by entering your full model number here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer. 25744469-2eaufixstlx223aid0wpxsf5-4-0_0.jpg
5/23/2016 6:41:59 PM • Samsung... • Answered on May 23, 2016
How do I remove the door
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove. Or you can watch a YouTube video (not a video I made) that demonstrates how it's done. In some cases, you then have to gently rotate the handle to unlock it. You can find helpful exploded view diagrams and order parts by entering your full model number here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer. 25744480-2eaufixstlx223aid0wpxsf5-4-0.jpg
5/23/2016 6:40:51 PM • Samsung... • Answered on May 23, 2016
Table rotator just spins won't move when on
Small motor under glass turntable needs replacing.
10/11/2015 7:49:09 PM • Samsung... • Answered on Oct 11, 2015
2answers
The 2 hooks(latch) inside the door have
For no apparent reason, the latch broke on the 9187 ST. Take the door off of the microwave,which isn't too hard. Rotate the door to 90 degrees, lift up, and slide it to the left. Place the door on the counter, latch side up. Use a thin knife or screwdriver to lift the panel that covers the latch. It is very easy to remove it from the door. Then slide the latch up and lift is out. The spring is under the latch. The clip on the latch that held the spring was fractured. So, I drilled a tiny hole in the body piece from where the clip extended. I reattached the spring to the latch, replaced the panel, replaced the door, and it is as good as new.
7/18/2015 2:55:02 PM • Samsung... • Answered on Jul 18, 2015
Samsung SMH9187ST Microwave Oven Logo
184 questions posted
Top Samsung Microwave Ovens Experts
Muzahura Frank
Steve
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
samsung microwave gives error code se
  • Microwave Ovens
