20 Most Recent Frigidaire FMV157GM Microwave Oven Questions & Answers
There is a door contact switch that is faulty.
Locate it then use your multimeter to check it.
Frigidaire... | Answered on Sep 16, 2017
Good Afternoon Howard, thank you for your post!
I am happy to assist you. I understand you are seeking the exterior dimensions on your Frigidaire microwave, FMV157GM. The unit itself has a width of 29-7/8 inches and the height of 16-1/2 inches. The unit has a depth of 15 1/32 inches. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
Frigidaire... | Answered on Nov 18, 2013
Hello Derrick Baker - Typically no fan should come on without starting the microwave. There is one exception! For an example, if the microwave becomes too hot from something that is cooking on the stove below the microwave, the fan will come on and will cycle off once the bottom of the microwaves cools back down. If the fan is turning on when the door is closed, more than likely, a door switch as failed. At this point, I recommend connecting with a certified technician to move forward accurately to assist with the repairs.
Frigidaire... | Answered on Mar 13, 2013
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Frigidaire... | Answered on Feb 25, 2013
Hello blackchow - Try resetting the unit flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and return microwave. If it proves to be ineffective, the unit could possibly be experiencing a wiring failure, faulty control panel or magnetron or an issue with the power supply. Contact a professional to move forward accurately and to assist with the repairs.
Frigidaire... | Answered on Jan 23, 2013
The service manual for the FMV157GM is here.
If we had symptom information we could help more specifically...
You can find helpful exploded view diagrams and order parts by entering your full model number or part number here.
If not, contact Electrolux / Frigidaire via the infdo on the front of the service manual or in your owner's manual.
Frigidaire... | Answered on Dec 27, 2012
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door. If the model number you have this listed under is correct, I found a replacement door handle at repairclinic.com for about $25. Look for item #1381096.
Frigidaire... | Answered on Nov 10, 2012
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
Frigidaire... | Answered on Nov 02, 2012
hi,
that is to keep **** from going into the interals.
by now you probably know what I mean. go to the hardware store and find something equivalent.
yes I can still spell.
jm
Frigidaire... | Answered on Mar 31, 2011
Check the door interlock switches and the bulb for short circuits.
Frigidaire... | Answered on Jan 06, 2011
Frigidaire FMV157GM Microwave Oven Logo
55 questions posted
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Microwave Ovens
Most Popular Question
am looking replacement item need same
  • Microwave Ovens
