Holly Tyas Posted on Jan 15, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won’t pick up paper - Office Equipment & Supplies
Aron
Level 3:
Top Expert:
  • Office Equip... Master 2,586 Answers
  • Posted on Jun 18, 2021
Aron
Level 3:
Top Expert:
Answers
2586
Questions
0
Helped
390310
Points
78544
There could be a paper jam with the photocopier or paper is stuck inside of the photocopier as well.
Canon Mp550 paper jam
If the paper is not being picked up from the tray assembly try applying mild soap to a soft cloth and clean the paper pick up rollers. Do not use rubbing alcohol because it will dry the rubber out so later they won't pick up at all
1helpful
3answers
HP Officejet 8500 won't load paper
check paper pickup rollers, check paper picking up unit weather its trying to grabbing the paper.If pickup unit not trying to grab its major mechanical issue..
Will not grab paper. says out of paper when its not
You can try cleaning the rubber wheels with alcohol. Sometimes they become covered in dust and won't grab the paper.
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
The feeder tray won't feed a document. I've cleaned out everything that I know of to clean out. I believe it may be the Document Set Sensor (I have a manual for the copier). I can't seem to...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
2helpful
2answers
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
2answers
k24674
ADMIN Andrew
ADMIN Andrew
