I cleaned the wires of each color several times but still get the error message. Drum life has 77%. Any suggestions?
Brother printers have somewhat particular parts, including the toner cartridge and the drum unit, in contrast to different printers. At the point when important, ensure that you supplant the printer's drum unit and not the area of the cartridge.
Step by Step Manual for Resolving Brother Printer Drum Error slide green tab:-
Stage 1: First, open your Brother printer's title page.
Stage 2: There is a Clean catch at the highest point of the catch. When snap the catch.
Stage 3: Click the Start button on the highest point of your printer beside the green shading segment.
Stage 4: You will see that your printer's presentation screen is turned off. Assuming this is the case, click the Plus (+) button 10 or multiple times again and again.
Stage 5: Now, press your printer's Ok button. An opportune screen showing the sign' Please pause' will be activated.
Stage 6: Close the printer title page intently once all the above advances have been done.
If facing any problem related to printer please visit us Brother Printer Drum Error slide green tab
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
SOURCE: Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
SOURCE: Our Brother HL4040CN is saying
The green tab referred to on the drum unit slides a thin wire across the drum to scrape off any built-up toner that has accumulated.
To do this, first open the door to access the toner/drum cartridges (it's the same door you'd open to replace a spent cartridge). Remove one of the cartridges; the inside of the door will have a sticker illustrating the exact steps to do this. Once you've removed a cartridge, look to the end that is inserted first when installing it (the end opposite the one grasped to remove the cartridge). You should see a small green tab here. Slide it left and right several times to clear away any blockage. For good measure, vigorously shake the cartridge side to side to evenly redistribute the remaining toner evenly inside the cartridge. Replace the cartridge and repeat these steps for each one remaining.
If you still get an error after following these steps, remove each cartridge and shake it extra vigorously for at least 10 seconds. Sometimes the toner can clump inside the cartridge, causing the printer to interpret it as a blockage. This is especially likely to occur if you live in an area with a humid environment.
