SOURCE: Canon IR-3300, error 354
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
SOURCE: How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
SOURCE: canon ir 3300 drivers
You can download the drivers for Canon ir 3300 drivers from http://www.usa.canon.com/opd/controller?act=OPDDisclaimerAct&fcategoryid=2291&modelid=6363&id=30079&file=/cpr/software/devicemanagement/HP_Output_Server_v3.5_Canon_imageRUNNER3300.zip
SOURCE: canon ir 3300 display shows error E000003-0000
RESETTING CODE E000003-0000 ON CANON IMAGE RUNNER 5000 COPIER
