20 Most Recent Canon LASER SHOT LBP 3300 Printer Questions & Answers
canon LBP3310 printer has alarm light is on what is problem
Canon LASER SHOT... | Answered on Apr 11, 2019
You might have to re-install the Printer Driver. Sometimes the registry can get corrupted. Re-installing the print driver can sometimes cure this error.
Canon LASER SHOT... | Answered on Apr 06, 2019
Uninstall the printer driver on your system
Again install the Printer Driver.
reset the Option fro printer driver
Thank you
This error is mainly due to components related to drying of the drying assembly, the control circuit drying from the main source.
Xe n?ng nh?t b?n
Canon LASER SHOT... | Answered on May 19, 2018
change tcp port to 9100
in port settings in printer properties
check firewalls allow access to port 9100
Canon LASER SHOT... | Answered on Nov 01, 2017
these instructions r for win xp
go to printers and faxes select canon lbp3300, right click and select printing preferences set out put paper size as A4.
Canon LASER SHOT... | Answered on Aug 14, 2017
This error is a Laser fault. Either the laser is very dirty inside or the polygon motor is not running to the correct speed. You need a Canon engineer for this repair as its well out of the scope for a user to do. A lot of stripping down to get to the laser is required.
Canon LASER SHOT... | Answered on Jul 02, 2017
Take out the cartridge and make a hole on the surface of the laser toner container with a sharp tool. Then you can refill the tonner inside it using one small coke.
Canon LASER SHOT... | Answered on May 25, 2016
This can happen du to pickup roller or rear delivery rollers.
your input on
(1) where do you find the paper folded ? front/ mid / rear section ?
(2) is the entire paper folded or only some part of the paper ?
(3) does it happen only when duplex option is used or regular
Canon LASER SHOT... | Answered on Mar 22, 2016
Hey, the paper sensor is located at the bottom of the printer, if you remove the paper tray, you will find it at the bottom of the printer, above the paper tray.
Canon LASER SHOT... | Answered on Dec 17, 2014
Canon LASER SHOT LBP 3300 Printer Logo
186 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
e000003 000
  • Office Equipment & Supplies
