Try uninstalling your PDF program, reboot and reinstall the latest version. It may be the way it is parsing the colours, if the Printer Test Page printed okay.
Your Cannon printer is not the problem. You will get different print color depending on the paper you are using, For example you will get different print result if you print on color paper than on white paper and a different print if you print on photo paper. Another alternative is to lighten the tone of your purple. I don't know what your objective is and what project you're working on but I hope this might help.
registration error which mean the colors are not laying on top of each other, in this case magenta (red) and Cyan (blue) giving you purple, need to have a tech come out and run regisrtation procedures
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
ahem...well..this has a lot to do with the rgb to cmyk issues on the transforms. You may need to see if the Photosmart is compatible with the Adobe Photoshop C2 transforms..
