PGBK Black ink not printing even after cleaning the print head then replacing it with a new one and then after cleaning the waste ink pad yet still nothing.
Hi Mark.
try this link.
https://www.google.com/search?client=avast-a-1&q=Canon+TS5050+Print+problem&oq=Canon+TS5050+Print+problem&aqs=avast..69i57.3376j0j9&ie=UTF-8
Could have ruined the head from not proper cooling from the ink supply.
Try to clean the head using 8 oz. hot water (preferably distilled) and 1 oz. ammonia.
Make sure the intake ports are submerged for 30=45 minutes. Dry the head completely and re-install.
Gently tap the PGI5 BLK on a towel and make sure ink comes out.
If so do a deep clean and a head alignment page.
If nopt you may need a print head that I can supply.
Thank you fo0r using Fixya
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads: -leave the printer on for a day -run several head cleanings and print the nozzle check pattern -if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer. -reinsert the cartridges -run one head cleaning -wait about an hour then run some head cleanings. -dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any ink-jet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
If after that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it. If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty. Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life. If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too.
this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech.
head cleaning and servicing will solve the issue
This will help.Thanks,please
keep updated. please do rate the solution positively .thank you for using fixya
