Washing Machines Logo
Question about Candy Washing Machines
The start/pause button is not working on my candy smart class a washing machine
The light flash and door did not lock
Anonymous
The pump is blocked up or the filter
once you take the blockage you need to reset the machine
too do this turn off the mains power
press and hold usually the start pause or menu button
and turn the mains on
wait a few seconds and let go
should clear the fault detection
if it is the filter or a blocked bad pump
and its clear then the machine will reset
Posted on Nov 28, 2014
  • 1 more comment
  • mahmoud Shahin
    mahmoud Shahin Jul 31, 2021
    Thank you. It is working, you are so professional
  • chinnam naveen kumar
    chinnam naveen kumar Nov 13, 2021
  • Sonia
    Sonia Oct 08, 2022
    Hi how do you clean this please and where is it on the dryer?
5 Related Answers
Anonymous
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
Anonymous
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
Anonymous
SOURCE: Candy Activa Smart 1300 AA
Many thanks had already done this and all is working fine now fingers crossed!
Posted on May 31, 2008
Anonymous
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
Anonymous
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
Hotpoint FDL 9640P U.K. Washer Dryer problem. Start/Pause button flashes every 3-4 secs.
That sounds like you are on Pause or Delayed Start. Try Pressing and holding the button. You can also try disconnecting from the mains for 5 minutes.
When in doubt, read the manual :>D
START/PAUSE button with indicator light: starts or temporarily interrupts the wash cycles. N.B. To pause the wash cycle in progress, press this button; the corresponding indicator light will flash orange, while the indicator light for the current wash cycle phase will remain lit in a fixed manner. If the DOOR LOCKED indicator light is switched off, the door may be opened. To start the wash cycle from the point at which it was interrupted, press this button again.
and also
! If the START/PAUSE indicator light (orange) flashes rapidly at the same time as the function indicator light, this indicates a problem has occurred (see "Troubleshooting").
https://manualzz.com/doc/50330217/hotpoint-fdl-9640p-uk-instruction-for-use
Start/pause light flashing green on Indesit washing machine but none operational
Try cutting the power again for 10 minutes. If it doesn't fix it, you will need a service call.
Simpson Ezi Set 7kg Front Load Washing Machine SWF7025EQWA 9315540408058
Press and hold the start button for 5 seconds. The child lock is on.
When I press the Start button on my front-loading GE washing machine, the door locks, then unlocks, then locks again, and the machine runs for about 12 minutes, then pauses and the Start button light...
One of the things to check is the door latching mechanism. It may just be loose. The numbers you provided are for the pedestal and not the actual machine.
Candy Go482 wash machine will not start its cycle.door security light flashing but no obstruction
It could be a bad door lock switch. I had taken my machine apart to clean the boot and accidentally dislodged one of the plugs (there were 3 on the mechanism) on the door lock mechanism. I got the same actions from my machine as you are. Since you probably haven't taken anything apart, a bad switching mechanism can cause the same problems.
1helpful
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
1helpful
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
1helpful
4answers
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Top Candy Washing Machines Experts
Marvin
Marvin
Kolbrun...
Oliver Street
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
