Machine stops before its finished the program and comes up E03 on the display
SOURCE: my hotpoint washingmachine WF860 comes with the message tESt
it's on test mode for the factory. this comes on if you hold the on and start buttons together. can be reset by turning on while holding both on until dOFF appears.
Posted on Jan 27, 2009
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
SOURCE: the washing machine does not spin and displays an
Make sure water pumping out if not check /clean filter
Posted on Oct 03, 2009
SOURCE: hi i have a candy
Hi The issue seems to be with the water not draining completely
from the unit, first check the drain pump-filter assembly located at the bottom
front of the unit. After this is done and the issue is still there then it
means that the pump assembly is bad and should be replaced. Hope this
helps...please post back for further assistance. Daniel
Posted on Mar 02, 2011
