Question about Candy Washing Machines
Candy grand'o 1400 has stuck, vanish stain light is flashing, as is 90 minute light. Door wont open. Have selected my normal cycle and this has not happened before. I have tried ''drain'' and also ''spin'' and even re-done the whole cycle, but this still happens. Please help!
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
THANK YOU! A new family with a 19 month old WILL NOT function without it's washing machine!
Life saver!!!
A dad.
I have a problem with my Candy Grand O 8kg washing machine. Sometimes the machine just goes on for hours. The first time it happened I had gone out and when I got back and had to 'manually' drain and spin it, my son's school clothes were all completely ruined.
Any ideas?
any news on above problem as mine doing exactly the same, we changed moter but still doing it.
I did the same thing show above but it doesn't working and door not open
Posted on Oct 27, 2013
Did you find a solution - mine is doing exactly the same!
Posted on Dec 28, 2009
just had the same problem. I removed the filter and washed it in the sink. Put it back! And the washer's still didn't work! So I filled a jug with water and pored it in to the drawer. Selected rinse pressed the start button and it worked.
I've the same problem with my candy machine aswell. I just manually run the rinse and spin cycles too. It's very frustrating.
How do i loosen motor on candy grand washing machine?Need to put belt back on
Posted on Feb 03, 2010
Yes, solved by following instructions above. As the man says be prepared for lots of water - filled bucket 1 1/2 times with lots of water on floor as well.
Posted on Jan 26, 2010
