Can you please tell me how to do a reset on a candy go482 washing machine
Try unplugging it for 10 minutes and press the start button while it is unplugged and that usually resets the system. If that does not work then you have a board or drain problem.
Posted on Aug 02, 2014
SOURCE: could you tell me why my candy go 482 washing
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Posted on Dec 28, 2009
SOURCE: machine wont drain
What you need to do is unplug unit for 30 mins, plug back in and try again
Posted on Jan 20, 2010
SOURCE: We have just purchased a GO482 Candy washing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
SOURCE: My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Posted on Jan 13, 2012
SOURCE: candy grand o go482/2-80 very noisy when spinning
The manufacturer, "Candy Products" http://www.candy-domestic.co.uk/about_us/Default.aspx is more likely to provide an authoritative answer than anyone else. They seem to manufacture their own machines, answers based on experience with other makes and models are of no value to you in regard to this question.
the foregoing aside, what one man has made, another man can also make, or repair. It is extremely unlikely that Candy paid to have an exotic one of a kind bearing made for this washer. However, even if the bearings are a common industrial part, that doesn't mean that removing and replacing them is easy or cost efective, or even the cause of the noise.
Unless you have more expertise than your question implies, perhaps you should ask to have a Candy repairman diagnose the noise and if your diagnosis is confirmed give you seperate prices for the bearings and the installation of same. From that you can discern how long the professional repairman familar with the machine would require to do the work, and you should double or triple it to estimate how long it will take someone unfaniliar with the machine to do it
Posted on Feb 12, 2012
