Printer wont work
SOURCE: Ink Cartridge Settings
Have you tried Canons FAQ? They suggest checking the grayscale box, which apparently only works with certain kinds of printing (duplexing and borderless will still use colors). I don't understand how colored inks are used to create black, but that's what they claim. Anyway, here's the link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11641
SOURCE: The MP620 printer has 2 black ink cartridges. The
With these types of printers they will use all 4 colors to make black unless you configure it other wise. The link below will take you to the printers support page. In the box that says "please enter your question" type "how to use only 1 black ink". it will give you top results, just click #1 and it click on your operating system. Follow the instructions given and that should take care of it. If you have any other questions feel free to ask.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=17406#SupportDetailAct
SOURCE: printer says set ink cartridge
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Hi Arleene Heeney, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Do the cartridges flash .
If so how many times?
