1, Double-click on the printer icon on your Desktop and select the Scan a Document or Photo option from it. Lift the Scanner lid and place the first page with scan side facing down.
2, Check the scan settings and click Scan document to file. Click the Scan button, and the scan process will begin. Now remove the first page and replace the second page on the scanner glass. Click on the "+" sign located at the left-hand side of the display.
3, In the same way, continue scanning other pages too. Once you completed scanning all the pages, click Done after saving the file with a file name.
4, You can change the destination name in the printer settings. In this way, multiple pages can be scanned as PDF.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
SOURCE: Scans
Are you using Acrobat? If so, you can insert pages easily by using the Insert menu. It will even allow you to choose where to insert the page - first, second, last, etc.
SOURCE: Scanner saves multiple pages separately, need saved as one
hi,
thats very easy, i believe so ur trying to scan from the printer itself becoz that happens if u try to scan from the printer itself, instead of that use the solution center software.
if u have installed the complete software which was provided by hp, u will a icon on ur desktop called solution center, click on that and click on the scan document button on it and u get a pop window in that select the file type as PDF and click on scan at the bottom of the window and once it completes the scan, it will give a message do want to scan another page, click yes and go ahead with that........
i think i have answered ur query..............
Regards,
raj_p5983
SOURCE: Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
SOURCE: Want to scan several pages as one pdf document
Try OCR Terminal,which is an online OCR service that converts scanned images into searchable text. Register an account and you can convert 20 pages for free every month.
Have a try and hope it helps.
