Cant log in with Admin and no password or Administrator and no password. How do i enter SP too?
SOURCE: I forgot login password for Ricoh Aficio MP2000 copier
Try getting into service mode and see if you can reset the user passwords by turning them off in the settings.
Do you know how to get into service mode?
SOURCE: Asking user name and password in Ricoh Aficio MP2000 copier
Pull the litium battery off of the printer card and put it back in. That may reset the password unless it wrote it to the hard drive.
SOURCE: im trying to install hp psc 1510
make sure everyone is logged out,try getting rid of all accounts and then try to install if that doesnt work call hp support!! hope this helps!!!
SOURCE: WHEN INSTALLING IT SAYS CANT NEED LOG IN AS ADMIN.
DO THIS , press the SET UP button and go to
RESTORE DEFAULT , let me know if it works this time , AJ
also you might try
when you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
When you boot up to the log in screen type in administrator to log in if you cant log in
or
hope this helps
