20 Most Recent Ricoh Aficio 1018D All-In-One Laser Printer Questions & Answers
samply clean exposure glase and mirrors carfuly
Ricoh Aficio... | Answered on May 09, 2015
Could be photoconductor gears are bad will have to replace unit or fuser unit you will have to decide which one first
Ricoh Aficio... | Answered on May 29, 2014
Remove all paper from unit and carefully check in corners for a paper jam or staple/Paper clip
Ricoh Aficio... | Answered on May 28, 2014
just clean mirrors and expsure glas
Ricoh Aficio... | Answered on Apr 28, 2014
get in user tools and sigen in as supervisor and change password
first do u hv a scanner and printer connection board in ur machine.if not its imossibal to work u must get one and install it.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
www.p4photel.com
http://www.websitetoolbox.com/tool/mb/copierquestions
194
B SBU White Level Detection Error
The automatic SBU adjustment failed
twenty times consecutively.
• Exposure lamp defective
• Dirty white plate
• Incorrect position or width of white
plate scanning (☛ SP4-015)
• BiCU board defective
• SBU board defective
Problem with the scanner. Check the white registration strip. and clean the mirrors. normally works.
Ricoh Aficio... | Answered on Feb 14, 2014
Try admin and leave password blank if that doesn't work then log on to web monitor . Open your web browser ie or Firefox doesn't matter enter IP address in browser then log in as supervisor no password and change name and password
Ricoh Aficio... | Answered on Jan 23, 2014
replace the thermistor and thermostatic some time maye be power supply
Ricoh Aficio... | Answered on Aug 10, 2013
If you can see it, it is set up right, however, the configuration might be wrong. Go to printer properties in the control panel. Open up the ports tab, select configure port. You will see that it is probably set: protocol:Raw, port:9100. Sometimes the port is 10001. Otherwise, set it to LPR, and put LP1 for the queue Name. That should do it.
Ricoh Aficio... | Answered on Oct 22, 2012
Ricoh Aficio 1018D All-In-One Laser Printer Logo
59 questions posted
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
ricoh 1018 copierscan light not coming
  • Office Equipment & Supplies
