Can reset error SC194.
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
- Possible causes -
· Polygon mirror motor defective
· Poor connection between the polygon mirror motor driver and the BICU board
· BICU board defective
- Possible causes -
· Charge roller damaged
· Charge high voltage supply board defective
The fusing temperature goes 10 °C below or 10 °C over the stand-by
temperature after warm-up is completed.
- Possible causes -
· Thermistor defective
· Poor connection of the fusing unit
· Power supply board defective
To reset a SC564 , enter SP 5-810 (SC code reset) and select
"1". Then hold down the Photo mode key and the key at the
same time for at least 3 seconds (this does not require the main
switch to be turned off and on).
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
?· Turn off the camera.
?· Remove the battery pack.
?· Press and hold the power button for 30 seconds.
?· Allow the camera to remain without power for 60 seconds.
?· Reinsert the battery pack.
?· Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Thanks,
KenSolutions
FixYa
