When I turn my washer on all of the lights come on, but when I turn the dial to select a cycle nothing happens. It will start when I press the start button but it goes to the normal cycle. I can then pause the machine and change the water temp, and speed, but only the normal cycle can be selceted.
Any info you can give me would be very helpful.
thanks
marykate
The LG washers are very buggy. Yes buggy. They have an on board computer that to this day still has issues. This sounds to me like the computer is confused about cycle changes. The component is also quite difficult to change. On ether side of machine are screws that need to be removed to lift lid. There are 3 modules inside. you will need to look at the wires to see where the largest sum of wires come together. That will be the main unit. Hope this helps. Good luck.
