Question about LG WM2301H Washer
I have an LG washer model WM2301H. When I turn the machine on the panel lights up but when I turn the dial to select a cycle it no longer makes a noise while turning the dial. How do I fix this?
Chime while picking a cycle is not working
Posted by Kelly Vieira on
ivan whisker
    Genius:
  • 1,164 Answers
Sounds like the clock or dial has gone if so a very expensive part to replace some times cheaper to buy new washer
Posted on Sep 24, 2012
5 Related Answers
SOURCE: LG front loading washer is turning itself on,then off
You have a fault microprocessor, or the "Brain" is sporadically faulting... You need to get this looked at... it isn't a minor thing unfortunately... look get a firm "Quote" from a reliable service center man
Posted on Feb 01, 2010
cj2176
Chris Jones
  • 520 Answers
SOURCE: my lg washer turns on but i cannot select which cycle I want
The LG washers are very buggy. Yes buggy. They have an on board computer that to this day still has issues. This sounds to me like the computer is confused about cycle changes. The component is also quite difficult to change. On ether side of machine are screws that need to be removed to lift lid. There are 3 modules inside. you will need to look at the wires to see where the largest sum of wires come together. That will be the main unit. Hope this helps. Good luck.
Posted on May 07, 2009
Anonymous
  • 95 Answers
SOURCE: LG WM0642H front load washer making a loud vibration-type noise
mc not level
Posted on Nov 18, 2009
Anonymous
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
Anonymous
  • 5 Answers
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
Posted on May 30, 2010
LG WM2301H ball bearings issues
See my answer on your prior post!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Apr 16, 2014 | LG WM2301H Washer
Lg wm2301h turn on by itself
This is something that you NEED to call LG on and have them fix it! Because I can tell you it is a fault in your computer board. Cost $200-700 dollars!!!! Yeah right! If you need to replace the Brain of any unit you might as well get another unit. It was faulty from day One!!!!
Apr 06, 2014 | LG WM2301H Washer
Lg wm2301h keeps saying oe
problem with water not draining..kindly check drain motor..
Feb 05, 2014 | LG WM2301H Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Power surge - washing machine Not turning on.
Instructions Things You'll Need:
  • GE/ lg washer
    Primary Method---Newer models
  1. Step 1 Unplug the washer.
  2. Step 2 Twist the control dial around the cycle settings.
  3. Step 3 Place the dial on any setting other than the final spin.
  4. Step 4 Ensure that the water line is securely attached to the washer.
  5. Step 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
  6. Alternate Method---Older Machines
  7. Step 1 Turn the dial around the cycle settings, but do not lift it to start the cycle.
  8. Step 2 Unplug the washer.
  9. Step 3 Plug the washer into the wall after 30 seconds without power.
  10. Step 4 Lift the washer lid five times, making sure it reaches a height of at least 6 inches or more. There should be no more than a 15-second interval between lifts.
  11. Step 5 Listen for a clicking noise. If a click is not heard, repeat steps 1 to 5 until you hear it.
  12. Step 6 Place a small load of laundry into the washer and start the cycle.
  13. Step 7 Watch the load throughout the wash to ensure the washer is working properly.
Dec 26, 2009 | LG Washing Machines
My lg washer turns on but i cannot select which cycle I want
Apr 25, 2009 | LG WM-2277HW Front Load Washer
How do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Mar 07, 2009 | Bosch Washing Machines
LG WM2301H Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
