20 Most Recent LG WM2301H Washer Questions & Answers
Take top of washer off-2 screws in back, slide rearward two inches and lift up. Check the hoses on top of drum.
LG WM2301H... • Answered on Aug 27, 2017
Make sure the washer is level, especially front to back. Do not overload washer. Check to see if marks are coming from build up of gunk in the outer bowl.
LG WM2301H... • Answered on Aug 28, 2016
I can almost certainly tell you that Your Pump is gone! There is no way to check them because the symptom you describe is the check! The pumps go for $35 to $135. So shop around and get ready to take your entire machine apart. Good luck If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
LG WM2301H... • Answered on Feb 10, 2016
Usually inside the tub door on the machine or on the back (top area) by the power chord. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
LG WM2301H... • Answered on Dec 15, 2015
Jeff I Hope since 2013 you still don't have that Code. If you unplugged it (for 30 minutes) then power it up. It should work If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
And Your question Is?????? If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
And you want it to WORK!? Gosh...I guess you Need to replace it! But first you need to order one! Go Here:https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=LG+WASHER+PUMP To Replace the Pump watch this
Don't you Just hate that when it happens? It's like a child that won't sit still! It will not Drain? Boy, you sure expect a LOT from your washer!!! OK, SORRY I was just having some weird fun. You have a Bad Pump. LG washers usually only have one, some washers have two! You can go here to order one:https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=LG+WASHER+PUMP&tbm=shop AND...If you want to do the repair, Go Here:https://www.youtube.com/watch?v=8cPl22OC9f4
There is a safety (Anti-Child Entry) switch that is not resetting. First try to reset the machine. This is done by unplugging it from the power source for 30 minutes and then plugging it back in. If that doesn't work you need to Push the Wash Button X 3 seconds to disable it. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Bill! Boy if I was an appliance repair person. You would have Paid my Mortgage for one month + with the problems you Posted on this single machine. Next time place them all In one simple question. Thank you. By the way your machine is Shot! Dead, You definitely Need a Newer/new one!!! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
OK, On my prior post for your LG I answered this question (One of four) you posted! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
See my answer on your prior post! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Lets see here I read that you have three separate problems. Uhhhh 1) Ball Bearings 2) Hard reset 3) Going on 4) Serial number Now I'm going to give you a method to start with, complete, then move to next issue. FIRST!!!!! Get you owners manual and turn to the LG page for Customer Support. Now, if you sent your Registration card then They will have the serial Number. Other places back of machine, Tub opening inside/behind door.Now "If" you're having ALL these problems there is a chance here that you need a NEWER/NEW one under warranty to be replacing the machine you have. NEXT.... Turning the Machine Off/On by pulling the Plug (ALL THE TIME!!!) Is a symptom of the Computer Board (Brains) has a fault (broken) and needs to be replaced. These are VERY expensive $300-$700 depending on model, yr bought, And if this is the issue and you have no warranty left. Buy another LG ERRRRR! Stop! Stop! Whatever you do DO NOT BUY ANOTHER LG MACHINE!!!! When Mine went after 8.5 yrs I had the same problem as you. I bought a "Used" Whirlpool (Commercial Grade) for $150. I have had THAT machine for 16 yrs! No problems AT All. So look at Top Loaders Whirlpool (Duh!), Maytag, or Samsung. To "Reset" your machine you disconnect from power for 30 minutes then plug in/ Ball bearing are Not on these machines, they use a thing called a Stader. Which is a MAJOR replacement issue. Finally...Who told you that you had these problems? Hope it works for you, please let us Know! We are here to assist you! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
This is something that you NEED to call LG on and have them fix it! Because I can tell you it is a fault in your computer board. Cost $200-700 dollars!!!! Yeah right! If you need to replace the Brain of any unit you might as well get another unit. It was faulty from day One!!!! If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
LG WM2301H... • Answered on Dec 13, 2015
check ur motor coupler LOUD NOISES IN washing MACHINE; LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights. THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it. THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS, THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced. The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs. A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket. In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions. If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced. Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel. All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair. Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well. If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it. Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration. By the way my advice is free cuz God is good! GRINDING NOISES: The plastic drive is known as a splutch (splined clutch). One problem with these washers has been loosening of the nut that locks the pulley to the agitator input shaft. If it gets loose, the pulley drops and the teeth no longer have good contact with the teeth of the splutch basket drive gear in spin mode. The solution is application of blue locktite to the threads of the input shaft. There have also been a lot of failures of the actuator that operates the cam ring of the splutch which raises and lowers the basket drive gear. It is raised for agitate mode and lowered for spin. There is a spring between the basket drive gear and the gearcase housing that maintains pressure on the basket drive gear. There are cams on the cam ring that ride up and down on cams in the splutch cam (housing) as it is rotated by the actuator thus raising and lowering the basket drive gear. The gearcase has a planetary gear set in it. 14629893-0ibogqi43422e0jrk2ickvgv-2-0.jpg 14629893-0ibogqi43422e0jrk2ickvgv-2-2.jpg 14629893-0ibogqi43422e0jrk2ickvgv-2-5.jpg 14629893-0ibogqi43422e0jrk2ickvgv-2-9.jpg
LG WM2301H... • Answered on May 25, 2015
check pump
LG WM2301H... • Answered on Feb 18, 2015
problem with water not draining..kindly check drain motor..
LG WM2301H... • Answered on Feb 17, 2014
LG WM2301H Washer Logo
57 questions posted
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
lg wm2301h wont drain tried cleaning
  • Washing Machines
