1) If the error code E 2 displays on the printer's control panel, the machine is out of paper or paper does not feed.
2) Take the paper from the input tray and after a while, reinsert it. Press the Black or Color button to check if the issue is resolved.
If there is any printer related queries just give a call @ 1-866-293-9220.
My printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at [email protected]. thank you.
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: Black Ink Line when I print anything
This problem is probably caused by an overflowing waste ink reservoir pad. You need to get someone to change it.
SOURCE: driver for canon pixus ip 3100 printer driver
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10238
Select your OS and download.
PS, please dont forget to rate this solution as Fixya once you're done! thanks in advance.
SOURCE: ERROR CODE e0000002-0000
it is a fuser error. you have to go into service mode to reset the error. e002 is usually from a power spike or drop, it doesnt have to be much.if the error will not reset then the fuser assy needs replaced.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
SOURCE: please show me step by step to fix error 5110 in
This is a carriage error.
1. Printhead is stuck to the docking area either because some old ink has become like glue.
2. A piece of paper got over there and is jamming it.
3. The spring is weak and is not pulling the docking area down.
4. The Purge unit has failed and needs to be replaced.
Turn the printer off and then slide the printhead to the left and
use a flashlight to see if you see any paper stuck around where the two
sponges that where sitting below the prinhead or if it just didn’t
lower like it should have.
printer model is IPF6300 . the printer was transferred to another place. and tried to run and it was printing okey, and suddenly printer stop printing and showing that error. I try to turn the machine off and on again..but still the same problem..what would be the cause of this error?
