Prosperity M. Mbiko Posted on Oct 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its about my canon 7540 printer gave an error b203 how to resolve so that i would be able to print
Robert john
Level 3:
Master:
  • Canon Master 301 Answers
  • Posted on Jun 18, 2021
Robert john
Canon Master
Level 3:
Master:
Answers
301
Questions
10
Helped
265800
Points
1441
Canon Printer Error Code b203 is a very common problem that appears frequently on all Canon printers. This error message usually occurs when users try to execute a print command, but the printer cannot execute it correctly due to operational issues. Most of the time, the reason for this error is related to simple internal printer problems.
However, sometimes the system or connected device is also responsible. Now, if you are one of the users facing the Canon B203 printer error code, you can follow this Blog to solve it. Canon Printer Error Code b203 relates to the major parts of the system and the printer. And, to implement appropriate and effective solutions, Canon printers must detect parts-related problems and then implement solutions accordingly.
Canon Printer Error Code b203 is usually seen when we try to print a document and the printer is unable to do so because of some workability issue. Follow our blog for the complete solution of Canon Error Code b203.
Related Question: B203 error won't clear on MG7720 cannon printer
Website: www.printererrorsupport.com
Jessica Michael
Level 3:
Master:
  • Canon Master 459 Answers
  • Posted on Nov 02, 2018
Jessica Michael
Canon Master
Level 3:
Master:
Answers
459
Questions
Helped
305139
Points
1452
1) If the printer shows this error, it can be fixed by opening the cartridges access door and closing it.
2) If this is done, the carriages of the printer moves from one end to the other end and in the end it comes to a rest point where the nozzles get ready to print.
3) If this is done correctly, the issue can be fixed on the printer easily.
Nicola Conroy
Level 3:
  • Master 1,428 Answers
  • Posted on Oct 19, 2018
 Nicola Conroy
Master
Level 3:
Answers
1428
Questions
Helped
714202
Points
3702
. .Could be it's a blocked or damaged print head.
Failing that try to open the machine then plug in and as the heads moved close the lid after that it worked.Or try turing off machine, Open the printer like you will be inserting ink cartridges, turn on printer, when the cartridge/printhead unit starts to move, close the printer. When I did it it did a self check for 3 to 4 minutes and when it was done it was ready to print.
Don't know if it will be a permanent fix as I don't know why it suddenly stopped working, but it is working now.
5 Related Answers
A
Anonymous
  • Posted on May 01, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Anonymous
  • Posted on Feb 14, 2009
SOURCE: error message on canon i900D
1. Underneath the printer, look for the triangular arrow on the AC Adapter, which points to a detent. Fully depress the detent, remove the AC Adapter and unplug it. Align the cable so that it will pass through the hole in the case when you remove the printer assembly.
2. Open the front cover to the vertical position and tug it at the hinge points to remove it.
3. The black, card-slot cover has two holes marked by triangles. Remove the two Phillips head screws, being careful not to lose them in the printer mechanism. Coax up card slot cover with a dull knife or similar tool and remove it.
4. On the top left of the printer, notice the triangle point at a slot. Insert a screwdriver or similar tool into the slot and depress the detent. Ease the little cover over the USB cable connector towards the rear of the printer and remove it.
5. Remove the “Operation Panel and Window Display” (OPWD). Lift the window display to the horizontal position and remove the two Phillips head screws. Rotate the OPWD forward and out the two hinges at the bottom. Lower the tiny snap that holds the OPWD strap cable and remove the OPWD.
6. Note the slot marked with a triangle between the two OPWD hinge slots. This is one of the six slots, all marked with a triangle, which access the detents that hold the upper casing. Locate the other five. One is on the left-side front of the printer in the same relative position as the one hidden under the OPWD. The other four are in the rear of the printer. Depress these detents in turn, working around the printer, and coax up the upper casing. This requires fortitude, patience and one or more dull, thin instruments.
7. On the right side of the printer, remove the Phillips head screw that fastens the yellow wire to the chassis of the printer.
8. Disconnect the connector on the Digital Camera Connector (DCC) circuit board and ease the cable out of the printer casing as far as you can. (I feared damaging the connector and removed the circuit board and DCC cover instead.) This cable is hooked at the right hand rear corner of the printer casing.
9. Looking down on the printer mechanism, locate the two Philips head screws near the rear. These fasten the printer to the base. Remove them carefully.
10. Placing a hand under the paper feed barrel, lift the printer assembly up and rest it on the case while you fight the DCC cable off the hook at the right rear corner. Once you free it, remove the printer assembly and congratulate yourself.
11. Wearing disposable gloves, remove the five ink absorbent pads and rinse them under the facet in the laundry sink. Cold water is fine. Press the pads with your fingers until the water runs clear. Do not wring or otherwise torment the pads, as you want them to retain their shape. Press the pads between old newspapers to squeeze out most of the moisture. Expect to be surprised at the amount of liquid these felt pads can hold. I dried mine in the sun. Use a hair dryer, clothes dryer, microwave or oven at your own risk.
12. Reassemble the printer in the reverse order of disassembly.
12.1. Insert the small absorbent pads first. The right side pad with the green facing goes on top. (I think.)
12.2. Caution: Before replacing the upper casing, note the small electrical gismo on the left side of the printer assembly. It has a slot that fits into the plastic wheel. When properly positioned, the gismo snaps into place. Make sure the gismo is correctly seated before replacing the upper casing.
Anonymous
  • 787 Answers
  • Posted on Oct 15, 2009
SOURCE: canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 09, 2010
SOURCE: error e4 pixma mp145
Hi there you try.
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
jackmailler6
Jack Miller
  • 3 Answers
  • Posted on Feb 08, 2017
SOURCE: How do I resolve E5 error message in my Canon printer?
To resolve this issues just review this link: https://medium.com/@vickyweff1/printer-support-canon-printer-e5-error-message-9085e23ab91e
Canon Pixma MX492 with error code B201. Can I fix myself?
Overheating Print Head. Probably needs replacing.
If your printer displays a displays a B200 or related (B201, B202, etc.) error, this means that the print head built into one or both of the ink cartridges has overheated.
Feb 24, 2023
Error Code: B200 / B201 / B202 / B203 / B204 / B205 / B206 ...
Oracle Service Cloud Support https://canoncanada.custhelp.com > answer_view > a_id
I have an error code B201 on my Canon MX492
JustAnswer https://www.justanswer.com > printers > jl83k-error-co...
Jun 15, 2022 - The B200 series error (including B201) indicates that "Print head Temperature exceeded" or "Cartridge failure". This happens when you were ...
1 answer · Top answer: Hi and Welcome to JustAnswer.com! My Name is ***** ***** I look forward to assisting you today ...
Printer Shows a B200 or Related Error (Models with Two ...
Canon Global https://support.usa.canon.com > ...
Apr 27, 2020 - error, this means that the print head built into one or both of the ink cartridges has overheated. You can attempt to replace the ink cartridges ...
2answers
Hi can you please help me i want to print but my printer is showing a support code B203.Its a CANON MG7540
It seems something wrong with your print head. Go check maybe something blocking it's way.
3answers
Canon mg7520 error B204
Please review this page: https://printertechsupportnumbers.com/blog/fix-canon-printer-error-code-b203
If these steps do not correct the problem, and if the unit is out of warranty, it is not economically repairable.
3answers
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
2answers
The printed output may be printed incorrectly. Clicking [Resolve Error], and then try to print again.
1helpful
4answers
Error 6000 mp280
1. Turn off printer
2. Unplug all cords
3. Press ON button 5 times in a row
4. Plug printer back in
5. Try printing
If this doesn't work, call Canon
1(800)-ok-canon
34helpful
4answers
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
Solution for "Canon PIXMA 600 has error code 6A00 Can this be resolved"
Hi
Same old errors ok
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
old marine
old marine
ZJ Limited
ZJ Limited
