20 Most Recent Canon imagePROGRAF iPF8000 Printer Questions & Answers
Follow these steps : Cause: The Voltage of the print head is abnormal.
Problems can be with:
-Printhead -head relay PCB -Carriage relay PCB -Main controller PCB
Steps to be followed:
1. Replace the printhead. 2. Cable continuity check. if continuity of the cable between the head relay PCB and the carriage relay PCB is abnormal, replace the cable. 3. Replace the head relay PCB. 4. Cable continuity check. if continuity of the cable between the carriage relay PCB iand the main controller PCB is abnormal, replace the cable. 5.Replace the carriage relay PCB. 6.Replace the main controller PCB.
Canon... • Answered on Sep 09, 2019
https://groups.yahoo.com/neo/groups/Wide_Inkjet_Printers/conversations/topics/2373
Canon... • Answered on Jul 23, 2019
03130031-2F13 A/D Converter external trigger output stopped
and the problem is main controler
Canon... • Answered on Jan 10, 2019
1. unplug data cable 2. go to service mode
Canon... • Answered on Dec 12, 2018
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at [email protected] thank you.
Canon... • Answered on Nov 07, 2018
This is a printhead error Remove the Printhead(s), clean the contacts,and replace in printer . Run nozzle check and try to print. If you are able to print a few pages then get the same error, the Printhead will need to be replaced. Good luck
Canon... • Answered on Sep 17, 2017
The nozzles are self bleeding.
Canon... • Answered on Jun 16, 2017
If you are lucky- air bubbles in the ink lines to the printhead(s) - which you can draw out using a syringe. If you're UNLUCKY it's the purge unit, and it has to be replaced.
Canon... • Answered on May 28, 2017
thre was a part of inks that didn't worked....so there is no problem of the machine but problem of the chip
Canon... • Answered on May 16, 2017
so long as you don't tilt 10+ degrees sideways and 30+ long ways, you allegedly don't even have to bother with the move printer mode; i couldn't get any info out of the so called service engineers by phone after my display said "consumables need replacing, call service", so i didn't even bother with level 1 drainage. I even had steep cambered paths to negotiate. So long as you get 4 people and have a 2 way spirit level each end, coordinate and take care, there shouldn't be a problem. Also, avoid vibration and heavy knocks as on rough floors and doorways
Try to update the firmware version to 1.32 (latest version on www.canon-europe.com).
Then check the move of the carriage unit if any foreign object is on the move.
Last try a lubricate the shaft and replace the shaft cleaner.
your problem is on left print head and you must change it in service mode.
your printhead needs to be replaced
problem in the move of the carriage unit. Check visually if there is any paper inside the machine.
Check and come back later for more information
Canon imagePROGRAF  iPF8000 Printer Logo
336 questions posted
old marine
old marine
efs_perpends
efs_perpends
View Most Popular
imagePROGRAF Canon
  • imagePROGRAF Canon
Most Popular Question
close carriage cover ipf8300
  • Office Equipment & Supplies
