Posted on Aug 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mp258 error p07
Resetter
Refresh Cartridges
Level 2:
Sergeant:
  • Expert 241 Answers
  • Posted on Sep 12, 2012
Refresh Cartridges
Expert
Level 2:
Sergeant:
Answers
241
Questions
0
Helped
75422
Points
609
This seems to be an issue will a full ink absorber. This guide shows how to reset the counter and if the comments are to be believed it works a treat.
9helpful
2answers
How solve error p07 in canon mp287
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
  1. Turn off the printer without pulling the power cord.
  2. Press and hold the RESUME button (Green button), keep holding it and then press the power button, do not let go yet.
  3. Keep holding the power button, now release the RESUME button and then press theRESUME button for 5 times and quickly release the POWER button.
  4. When the printer entered the Service Mode, all LED will stop blinking.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
  1. Insert some A4 paper, the printer will print the result.
  2. Look for "Clear Ink Counter" section, press the "Main" button and wait for the message "A function was finished" and then press "OK" button.
  3. Press the "Platen" button located beside the "Main" button.
  4. Look for "Print" section, press the "EEPROM' button, select "Rear Tray" and pres "OK" button.
  5. The printer should printout the result. That's all, you may turn off your printer now. Sometime you need to press the POWER button several time in order to turn off the printer.
source:http://stepblogger.com/tutorial/tutorial-how-to-reset-canon-pixma-mp287-using-resetter-tool/
7helpful
2answers
Reset canon pixma mp258
Reset Canon MP258 error 5B00 or P07
Indications
When the printer is turned on will show an error MP258 P07 in LCD panels and monitor screen will pop up an error 5B00.
Resetter Canon MP258
1. The printer must be in SERVICE MODE, the way
2. MP258 printer is turned off and plugged the power cord.
3. Press the STOP / RESET and hold, then press and hold the POWER button.
4. The power button is pressed, release the button STOP / RESET, then press the STOP / RESET two times, then release both buttons simultaneously.
5. MP258 printer will process (rather long), then the LCD Panel will show the number zero (0)
6. The computer will detect NEW DEVICE, Ignore it .....
7. This situation indicates the printer is on and ready to reset SERVICE MODE.
8. Download ServiceTool_V1074 for MP258
9. Extract file ServiceTool_V1074
10. Prepare 2 paper in the printer (this is to print at the time the reset process)
11. Run the program ServiceTool_V1074
12. Click the "MAIN", then the printer will proceed, then MP258 will print one page with the words "D = 000.0"
13. Click " EEPROM Clear ".
14. Then click "EEPROM", and the printer will print the results MP258 Re-setter.
"TPAGE(TTL=00000 COPY=00000)"
15. Turn off the printer by pressing the POWER button or unplug the power cable
16. Turn on the printer, and the printer ready to use
I hope this information helps. Thank you for using FixYa!
1helpful
2answers
Canon pixma mp258 error 5B00
Please go to the following website which describes the procedure needed to fix your printer. You will need to download a resetter, the link to everything is in the instructions:
http://ekohasans.blogspot.com/2011/02/how-to-fix-mp258-p07-error-5b00.html
How to resetter the error p07 for printer canon mp258
Turn off the machine, and unplug the power cord of the machine from the power supply.Plug the machine back in and turn the machine back on.
27helpful
How to fix canon mp258 error code 006
i'm using canon printer mp258, the printer wont print anything after i refill both ink(color & black), the both l.e.d still lid and and the alarm l.e.d still lid and the printer window keep popping telling me the colors now empty..heeeeellllppppp.........
1)try to reset the printer - wont work
2)try using the resetter - wont work(error 006 occur)
9helpful
2answers
My printer canon mp258 show error 6000, how can I solve it?
You will need to reset your printer and this printer requires a software resetter fo many of its error codes. The newest and best available resetter with full instructions is available here.
Just follow the easy instructions and download their service tool and this should reset any error codes or problems you are having with the printer.
Hope this solves your issue.
5helpful
2answers
Canon pixma mp258 error 5b00, haw can i solve it?
I searched under mp258 on the canonusa.com website and found nothing on it.
There was an mp250, though. Was this model marketed in the U.S. or abroad?
When I input error 5b00 I came up with a series of hits:
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#ServiceAndSupport
The above describes how to shut the printer off and turn on again.
There were quite a few hits, but none referred to the 5b00 problem, specifically, unfortunately.
6helpful
How to fix Canon Pixma MP258...in it LCD show P07
P07 is a low ink level warning.
Have you recently replaced your ink cartridges?
Try printing something to reset the code, if you've just replaced your cartridges.
old marine
old marine
ZJ Limited
ZJ Limited
