If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
For Windows OS: 1. Go to Control Panel. 2. Open Printers and
Faxes. 3. Right-click on Lexmark
3600-4600 Series print object and click on Properties. 4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults. 5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print
using black ink only. Click OK. 6. Click OK button in the
Lexmark 3600-4600 Series Properties window to save the changes. Your printer will print in
black and white draft mode the next time you send a print job to the printer. For Mac OS: 1. With the file (you wish
to print) open, go to Print. A window will pop up. 2. Select the Lexmark
printer. 3. Expand the arrow
pointing down beside printer name if you're not able to see other options for
printing. Look for Quality and Media. 4. Under Paper tab, select Print in Black
and White. 5. Save this as your
default print setting. Click Presets option and choose Save as. You can
personalize the name for this default print setting (e.g. Black and White Draft
or My Setting).
Select this Preset name
every time you print your files/documents.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
Hi my printer it need cd drive and i don have and am trying to install i dont get online so what can ido my printer is lexmark 3600-4600
