aynalem Posted on Aug 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon image Runner 2202 error code E000-0000 - Canon Office Equipment & Supplies
L Pfaff
Level 3:
Top Expert:
  • Canon Master 11,573 Answers
  • Posted on Aug 21, 2016
L Pfaff
Canon Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587791
Points
181713
Aynalem, Canon image Runner 2202 error code E000-0000
5 Related Answers
Lance Farrell
  • 50 Answers
  • Posted on May 07, 2008
SOURCE: Canon 210S Image Runner
It is a fixing film position error. The fixing film is probably damaged or is just tracking off center. If the fixing film is ratched then replace the entire upper fixing unit. You can get just the film but its a job even experienced techs cringe at. Check the lower roller and bushings while you are at it. If anything is worn there it can cause the film to track off center.
Anonymous
  • 67 Answers
  • Posted on Aug 19, 2008
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Anonymous
  • Posted on Oct 15, 2008
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
color_50
color_50
  • 22 Answers
  • Posted on Mar 14, 2009
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Oct 13, 2009
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
2answers
Error Code E019-0002 for canon 2202 please help me
There's a good discussion about what to do for that particular fault code in Canon Image Runner laser printers in this link.
Canon iR1020 E019 0002 Error Code
How can I enter to setup of canon image runner 2202
Hello. you need to replace the fixing heater unit to clear that error
2answers
2answers
Canon ir 2202 error code e0141-0000
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR2200
129helpful
5answers
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
old marine
old marine
ZJ Limited
ZJ Limited
