20 Most Recent
Canon iR 2022 Printer Questions & Answers
How i do scanner in canon ir2022
connect computer to networkinstall canon color network scangear, select printer ip in this software.now you need scanning software. I'm using freekapture.place document in printer scanner. click scan button on printer.open freekapture and start scanning
How can I fix an error code E007 on a canon IR2022 copier?
E007
0000-
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause-
The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution-
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO:Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal:5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440 msec OFF
NO:If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES:Replace the fixing film unit.
NO:Replace the DC controller PCB.
Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*)
Try this - Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
System error E007 Canon IR2022 whit is prablume
Error Code, Sub Code, Code Explanation
E007
0000
Fixing film sensor failure
The fixing film sensor is faulty.
Before you replace the fixing film sensor, you might wanna try this first!
Download and install the newest version of the printer driver. If that doesn't help then check the papers size.
If you are using A4, then you have to make sure that it is actually the correct dimensions. the link below might help you with that.
Welcome to A4PaperSize org
Ir2022 system error e007 vido
E007
0000
Before you change the fixing film, then download and install the newest driver for this printer. If that doesn't work, then check if the paper size is correct. It might be on A4, but you have to check if the dimensions are correct.
This might help with the dimensions
