I have toner streaks across many of my canon c2880 printed 8 1/2 X 14 papers.
These streaks are not solid, but in tiny lines about an inch or two wide. appear on my 8 1/2 X 14 prints. Sometimes lighter and sometimes darker. I've cleaned the toner cartridge bays, have replaced toner. Still there! Help!
If the streaks are narrow black and run the entire length of the page, replace the soft plastic wiper blade on the drum (and hope the drum is not scratched). Black smudges are related to the toner/developer purity. Replace both.
Hello, is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
A) Black Streaks, Shadows, And Ghosting Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears.
Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Chances are you have a bad toner. The lines a spaced about the same width as the diameter of the drum on your blue toner. Shack the toner and try again. The toner may also be spilling toner into your printer.
Check your Toner Carts. Is the line a certain color? Black perhaps?
Lift the door of the toner cart. If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well. Is there a problem with the big orange roller? BEWARE! Don't touch the fuser roller its EXTREMELY HOT! Let the printer cool down before inspecting.
