STR-K502P
When I turn on I hear a click but no sound or lights
Any ideas
Hello Billy, obviously your STR-K502P, has problems in the main power supply, control you have to remove the cover and look for a fuse indicated as; F901 FUSE (6.3Amp / 125V) and fix it is burned, if so, before replacing it, you would have to get a lamp holder and an incandescent lamp of 200 watts, the old lamps that bring filament, and connect the cables of the holder lamp to the ends of the fuse holder, the lamp replaces the fuse (serial lamp), you connect the STR-K502P to the power network and turn it on, if the lamp turns on completely and stays that way, it is very likely that there are components damaged and are generating a short circuit, in this case I suggest you look for a specialized technical service
If, on the other hand, the lamp is turned on and off or the intensity of the initial flash is reduced, this would give a guideline that there is possibly no short circuit, you can test the operation of the STR-K502P in this situation, if you can hear it, then replace it the fuse, its value is 6.3 Ampere / 125Volts
Once this is done, do not use the STR-K502P, without first checking all the cables and connections of the speakers, corroborating that you do not have any short circuit in them
I hope you can solve it
Greetings Franco Dosil
Hola Billy, evidentemente tu STR-K502P, tiene problemas en la fuente de alimentaci?n principal,controla tienes que sacar la tapa y buscar un fusible indicado como; F901 FUSE de (6.3Amp/125V) y f?jate se esta quemado, de ser as?, antes de reemplazarlo, tendr?as que conseguir un porta lamparas y una lampara incandescente de 200 watts, las viejas lamparas que traen filamento, y conectar los cables del porta lampara a los extremos del porta fusible, la lampara reemplaza al fusible (lampara serie), conectas el STR-K502P a la red de energ?a y lo enciendes, si la lampara se prende por completo y se queda as?, es muy probable que haya componentes da?ados y est?n generando un cortocircuito, en este caso te sugiero que busques un servicio t?cnico especializado
Si por el contrario, la lampara se prende y se apaga o baja la intensidad del encendido inicial, esto dar?a pauta que posiblemente no hay corto circuito, puedes probar en esta situaci?n el funcionamiento del STR-K502P, si logras que puedas escucharlo, entonces reemplaza el fusible, su valor es 6,3 Amper/ 125Volts
Hecho esto, no utilices el STR-K502P, sin antes controlar todos los cables y conexiones de los parlantes, corroborando que no tengas alg?n cortocircuito en ellos
Espero que lo puedas resolver
Saludos Franco Dosil
