Hi Viv
In your scanning software make sure you are in the advanced panel.
There is a selection that says "scan to" or "Open with" and one that says "file type" (or something similar) - I'm not at a machine with one connected so I'm doing this from memory.
In the file type pull-down, select PDF
in the scan to/open with pull down select your email program.
After the scan is completed, a pdf will be created, you email program will open a new email with the scan already attached. All you have to do is address is, give it a title and send it.
Job done.
Here the manual http://www.manualservice.net/guide/free-pdf-manual-for-mp540/page/11
SOURCE: scan to pc
There's several ways to do this. I will tell you the easiest, (at least to explain).
1st- scan the document as usual, save it to your documents. ( to do this, look on your desktop for Canon Solutions- if not there it will be in your programs. This will open a box letting you scan from your scanner & save to your PC)
2nd- open an email, address it. Then click on the little icon at the top of your email that looks like a paper clip. This will open a box, just navigate to your documents & click once on the document that you want. This will put it in the email & you're ready to send. If you don't see a paper clip icon then click on 'insert'. This will do the same thing. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
1.
From the home screen, navigate to Scan to Computer: Scan > Scan to Computer
2.
Touch USB-Connected Computer or the name of a network computer. The local or
network computer is the destination that will receive the scan. Wait until the
printer has finished downloading a list of the scan applications available on
the selected computer.
3.
Select an application (in your case your email), and then touch Accept.
4.
Select the color, resolution quality and the original image size. If necessary,
touch Accept each time you make a selection.
5.
Press the start button to start scanning. The scan is complete when the application you selected
in step 4 opens on the destination computer, and the scan appears within the
application as a new file.
To scan to your computer using the printer software (Lexmark Printer Home):
For Windows:
1.
Click Start.
2.
Click All Programs or Programs, and then select the printer program folder from
the list.
3.
Select Printer Home.
4.
Choose your printer from the printer drop-down list.
5.
Click Email, and then select Photo, Document or PDF.
Note:
You can select Document only if an OCR application is stored on your computer.
Scanning starts and the scan progress dialog appears.
6.
When the scan
is finished, a new e-mail message is created with the scanned document
automatically attached.
7.
Compose your e-mail message. Note: If your e-mail program does not open
automatically, then you can scan the document to the computer and then send it
through e-mail as an attachment.
For
Mac:
1.
From the Finder desktop, double-click the printer program folder.
2.
Double-click the printer Center to open the All-In-One Center.
3.
From the "What is being scanned?" menu on the main screen, select a document
type.
4.
From the "How will the scanned image be used?" menu, choose To be viewed on
monitor/web page.
5.
From the "Send scanned image to" menu, choose an application.
6.
Click Scan.
7.
Retrieve the scanned image from the application, and then send it through
I hope this information has been helpful.
