Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR
Description
A fuser error has occurred.
Action
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below.
1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
SOURCE: hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
3. Faulty feed motor.
Action: Replace the feed motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
SOURCE: my HP Color Laserjet 3550 Printer wont print black
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
59.99 An error occurred in the secondary transfer engaging
mechanism. following four possibilities are mention below with proposed action:-
1. Faulty secondary transfer engagement sensor. Replace the
2. Faulty secondary transfer engaging solenoid. Replace the
3. Faulty feed motor. Replace the feed motor.
4. Faulty DC controller PCB Action: Replace the DC
controller PCB.
Good Luck
do Rate if got gelp
