HP Color LaserJet 3500 Printer Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
50.1 fuser error not fixed by instruction on machine; HP color laserject 3500
Anonymous
Level 2:
  • Expert 319 Answers
  • Posted on Dec 04, 2009
Anonymous
Expert
Level 2:
Answers
319
Questions
0
Helped
80880
Points
915
17 posts - 8 authors - Last post: 23 MarWe are getting a 50.1 fuser error with our Colour Laserjet 3500 printer ... fuser from HP in the UK, but was told that they are not currently available ... hi I have the same problem error 50.1 with two machine 3500/3550 ...
www.fixyourownprinter.com/forums/laser/31146
Error 50.1
Error 50 is a fuser error, probably you must change the fuser unit.
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
3helpful
Error 50.2 is displayed on HP 3500 screen
Try putting back the old fuser unit. If the machine works you have a defective fuser, even if it is a new one. If the machine still doesn't work you have a defecte high voltage assy. Gerrit Jan
Fuser 50.1 error on HP 3500 printer
From HP Website:
1helpful
2answers
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
1helpful
50.1 Fuser Error
50.1 error is usually a fuser low temperature error. The thermistor (electronic termometer) that controls high and low temperature is either obstructed, damaged or the heating element inside the fuser has been brokem or damaged. Carefully remove and inspect the fuser. If you have no obstructions then the fuser will have to be replaced.
Here's a link to the full service manual in PDF for free. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%203500-3550-3700.pdf
k24674
Grand Canyon Tech
Grand Canyon Tech
