SOURCE: i cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
SOURCE: "reinsert tape" message
I thought it was crazy too, but I fixed the problem by hitting the battery side of the camcorder with the palm of my hand. I'm going to by a new camera as soon as I can dump all my tapes from this one, but heah... at least it's working again.
Word.
SOURCE: TAPE WILL NOT EJECT BLEEPING AND FLASHING C;32;11
You need your CAM into Sony or service center Sony to repair it the error code is indicated the LS chassis assembly faulty or loading motor faulty it require a lot of work mechanis and electronics it may not worth to repair it. It would cost between $150 to $250 in AUS
Cheers
SOURCE: when i try to put it on player n play the tape it
http://www.agoraquest.com/viewtopic.php?topic=34628&forum=31
here you will find your answer.
SOURCE: WHEN PLAYING TAPE GET FLASHING NUMBERS C31 22
hi,
its a mechenizam problem , you must servise it properly and fix it properly , if you are a technition then cheak the machenizam flap also may be a little damage on it, if you find damage then replace it
