20 Most Recent Stanley 100 ft. Tape Measure, FatMax Questions & Answers
check coil spring inside might be broken or disengage to the tape measure.
Stanley 100 ft.... | Answered on Nov 29, 2009
You could do a bit of research as i can't remember the math's from my college days, but, it is possible to calculate the distance something travels by using its rate of descent against the time it takes to reach the ground, for instance, if gravity is measured at 9.81N/m per sec squared, then an object must speed up at the same rate from standstil every time unless the earths gravitational pull changed. If you then timed how long it takes to hit the ground you could do a simple calculation offsetting the rate of descent against time which would then give your distance. The calculation is - distance = speed x time, but you would need to factor in the the rate of change in the speed of the object from standstill to finish which is the bit i can't remember.
Stanley 100 ft.... | Answered on Oct 31, 2009
the electronic sensor eyes being off are the most common cause of this.
They need to be pointed at each other so they can "see" each other.
Commonly, the units have a light on them that will illuminate when they can see the other half of the unit on the the other side.
Also check the terminals that the sensors connect to, and make sure that they are connected.
Stanley 100 ft.... | Answered on Oct 27, 2009
you should be able to ----- how far to your nearest toolking store? you can still deal with them no matter where you are ---I deal with them all the time ,and I`m in australia
Stanley 100 ft.... | Answered on Sep 05, 2009
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel, polished granite, marble, porcelain, formica, enamel and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Stanley 100 ft.... | Answered on Aug 24, 2009
Use a second measuring tool and compare the results, or you can measure a known size or length (floor tiles for example)and check the reading you get.
Stanley 100 ft.... | Answered on Aug 21, 2009
You have acouple of options
You can buy a measuring tool that doesn't have a size limit or has a very high size limit, you can check around to find one that will suit your needs.
You can measure the till the end of you measuring tool, mark the spot where it ends, and make another measuerment from that spot.
Another option is to take a long piece of string, and run it between the two points you want to measure, Cut the rope exactly between the two points, and later you can measure it, section by section, this is a lot of work!
I'm sure that these aren't all the possible methods, I think that folks around here might add a few.
Good luck
Stanley 100 ft.... | Answered on Jun 03, 2009
there is an acrylic post inside that directs a light beam to several different places so when the light beam is broken then it tells other parts that the tape is loaded this could be broken off or if the tape broke off inside a piece could be wrapped around a capstan or drive post causing the machine to think it is at the end of the tape and to turn itself off.
Stanley 100 ft.... | Answered on Feb 13, 2009
Hi, Its sound like your compressor is not turned on. Make sure your compressor is plug in, and the (on and off) switch is turned on. Check the pressure gage to see what psi you have. You need at lease 90psi. If you don't have that much pressure, There should be an adjusting knob below the gage. Turn the knob until you get the proper psi.
If this doesn’t work for you, please write back. Thanks,
Stanley 100 ft.... | Answered on Nov 29, 2008
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Stanley 100 ft.... | Answered on Nov 23, 2008
51bc252.jpgThe handle on the right
Stanley 100 ft.... | Answered on Aug 03, 2008
BUY A CAN OF PENETRATING OIL AND SPRAY IT DOWN GOOD AND SOAK IT OVER NIGHT
Stanley... | Answered on Jul 17, 2020
i USE SCISSORS MYSELF
Stanley... | Answered on Nov 13, 2019
stanley fatmax jumpstarter 1000A light wont turn off?
Stanley... | Answered on Sep 09, 2019
Most stud finders have a sensitivity adjustment that should be carefully adjusted per instruction manual before use.
Failure to do this results in erroneous indications.
If you have adjusted exactly per the instructions with the same result the unit is probably faulty.
Stanley... | Answered on Apr 04, 2019
WHY HAVE YOU NOT TRIED IT TO FIND OUT FOR YOURSELF .
Stanley... | Answered on Mar 26, 2019
Stanley 100 ft. Tape Measure, FatMax Logo
14 questions posted
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Measuring Tools & Sensors
Most Popular Question
tape measure wont retract
  • Measuring Tools & Sensors
