Most likely it's a capacitor fault.
Google "Capacitor bulge" and then search Youtube for your make and model to see if anyone has done an instructional video. You'll need to be comfortable dismantling the TV and be able to use a soldering iron. If this isn't you then take it to a repair shop.
I'm sure all it requires is a "more" up-to-date recorder (although up-to-date doesn't exist for that these days because of all the DVD's and Blu-ray discs). I am not sure if you mean the problem that it keeps doing that (problem in the recorder. Or you get it repaired, or you get yourself a new one (cheap these days, I wouldn't recommend repairing). Or you're meaning the problem that the tape is now completely ruined. If it hasn't been damaged too hardly, you can get the tape fixed. Or you get someone to repair it, or you can even try it yourself. I'm sure there are things on the internet for that.
Is the vcr in a cold room? the heads might have dew on them
or need cleaned. If it keeps doing it you probly wouldn't want to fix it at a shop. you can buy new vcr's with remote at walmart now for $25-$30 I think. Hey you can try the old treatment
that i always do. Try unplugging the vcr from the electrical
outlet for a hour or maybe even longer sometimes that will resit
everything in it and it will work right.
It sounds like the LED might be burned out of it.
Is your VCR still under warranty? If it is, the manf. can replace it at no cost. Otherwise an LED doesnt cost that much to replace if that is the problem.
Did it do anything else before the problem happened?
Does it still work now? But you cant see the screen is all?
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
If it is a copy remote for the Proscan Model you have, it should work when you insert the batteries.
If it is a Universal Remote, you need to put the Proscan Code into it.
The Proscan PLED5544U is a 55-inch LED TV. While it doesn't have a physical reset button, there are a few ways you can reset it:
Unplug the TV: Unplugging the TV from the power outlet for a few minutes can help reset it. This allows any residual power to dissipate and can clear any minor software glitches.
Use the remote control: Press and hold the power button on the remote control for at least 10 seconds. This can sometimes reset the TV.
Use the menu: If you can access the TV's menu, you can try resetting it through the settings. Go to the "Settings" menu, then "System" or "General" settings. Look for an option to reset the TV to its factory settings.
If none of these steps work or if you're experiencing other issues with your TV, it may be best to contact the manufacturer or a qualified technician for assistance.
If your Proscan tablet and DVD combo is locked, you can try the following steps to unlock it:
Restart the device: This is the simplest and quickest solution. Simply restart the device by holding down the power button until it shuts off, then turn it back on.
Check the lock button: Some devices have a lock button that can be used to lock and unlock the device. If your Proscan tablet has a lock button, check to see if it's in the locked position and adjust it if necessary.
Reset the device to factory settings: If restarting the device and checking the lock button don't work, you can try resetting the device to its factory settings. This will erase all data and settings on the device and restore it to its original state. To reset the device, you may need to access the settings menu and look for an option to reset the device or perform a factory reset.
Contact the manufacturer: If you're unable to unlock the device using the steps above, you may need to contact the manufacturer for further assistance. They should be able to provide you with more specific instructions on how to unlock your device, or if necessary, repair or replace it.
I hope this helps! Let me know if you need anything else.
The model doesn't exist. All question need
'make model (what it is)', first 3 words and in that order.
"channel button". is it a television? Reset would be in Settings / General. You have the Remote? All sets need a Remote.
https://www.google.com/search?q=proscan+3373a
They make a lot of stuff!
Proscan Video - TVs, tablets, DVDs, and camerashttps://www.proscanvideo.comProscan manufactures and distributes quality electronics & appliances such as Televisions, Tablets, DVD systems, portable and home stereos, and cameras.Contact Us · Television · About Us · Manuals & Downloads
Proscan Tablet reset, Standard Android Hard Reset.
