Brother IntelliFax-2820 Laser Fax Logo
Posted on Jan 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Back cover open message although cover is closed
Anonymous
Level 3:
  • Master 488 Answers
  • Posted on Jan 15, 2011
Anonymous
Master
Level 3:
Answers
488
Questions
0
Helped
231294
Points
1359
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Getting error code 2200 on Lexmark P6250 Photo All-In-One InkJet Printer. Programme asked to refer to user guide. Error code not in user guide. Unplugged printer while on. Restarted PC then replugged...
hi
here is what i have found -- follow to all instructions accordingly
although its for another model, these isntructions apply according t their techsupport i spoke with
.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
here is where i found the error http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=2200 error#1
hope this helps -- God's speed
Although my cover is closed, I keep getting an error message that indicates, "The unit's cover is open. Please close cover." Please help me because I am unable to finish a large print job I have started...
Problem is simple, your system having sensor which indicating that cover is not closed. uncover it once and check sensor push button may be not connection well. recover casing and ensure its not loose.
Msg says printer cover open. Its broken, but closed. Can I copy?
There will be a microswitch that is operated by opening/closing the cover. Presumably the switch will be where you have a piece missing from the top.
You just need to find a way of closing that switch. That can be done mechanically with a piece of tape, or you could short circuit the switch if you can get to the wiring.
1helpful
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
2helpful
2answers
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
2answers
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
Norman Weimar
Norman Weimar
k24674
