20 Most Recent Olympus Stylus Verve / ?-mini Digital Camera Questions & Answers
How to download pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
11/12/2013 6:11:56 PM • Olympus Stylus... • Answered on Nov 12, 2013
How to download pictures from the camera to a pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
11/12/2013 6:11:27 PM • Olympus Stylus... • Answered on Nov 12, 2013
2answers
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
1/17/2013 4:08:20 AM • Olympus Stylus... • Answered on Jan 17, 2013
Won't connect to computer
happens to me too, is it because im using mac? they dont compatible with anything you know..
12/28/2011 6:53:19 AM • Olympus Stylus... • Answered on Dec 28, 2011
Why is my camera says "the card is full" when I
thats because the resolution of your picture was so big. try to reduce it by clicking the ok button, search for the resolution and then change it. go back to take a picture, and try it on. it works for me
12/28/2011 6:49:02 AM • Olympus Stylus... • Answered on Dec 28, 2011
I keep losing date and time function. I was told
Welcome to FixYa.
One possible reason why do you keep losing the date and time is just because you left the camera for a day with the battery removed. The date and time will revert to the factory default settings.
I have here the link wher you can see the steps and image on how you can set and save the date and time on your camera. Just click here. Refer to page 86-87.
Feel free to send us your comments and suggestions if this solution was helpful
Thank you for using FixYa.
4/22/2011 4:25:56 PM • Olympus Stylus... • Answered on Apr 22, 2011
Even after my olympus mini
This is probably because the battery has been worn down after many charges or because it has been over-charged.
When charging devices with batteries you have to make sure that you don't over-charge them.
It happens though, batteries do degrade over time and the amount of charge it holds becomes lower.
The only solution I can think of is changing the battery or buying a new camera.
Hope this helps.
3/5/2011 10:19:16 AM • Olympus Stylus... • Answered on Mar 05, 2011
How do you close the lens cover? Should it be
yes i should automatically close the lens cover like sliding barn doors.
8/7/2010 4:20:53 PM • Olympus Stylus... • Answered on Aug 07, 2010
2answers
I turn the camera on
Eject the SD card from the unit, and make sure the little read/write protect switch on the SD card is set to unlocked.
Let me know,one done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
7/31/2010 9:52:00 AM • Olympus Stylus... • Answered on Jul 31, 2010
6answers
Olympus U Mini 5.0
hi...i also have this problem showed D:5E02, my suggestion is that turning on camera at the table (camera face on horizontal), don't put camera down/face to the floor when opening.
7/15/2010 3:34:36 AM • Olympus Stylus... • Answered on Jul 15, 2010
I have a problem in that I can view pictures on
this should not be happening
yhis ussually only happens if there is an error on the disk seek help from a camera/electrial repairs shop
5/21/2010 11:54:48 AM • Olympus Stylus... • Answered on May 21, 2010
The lense keep on closing.I cannot take a
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/19/2010 10:50:38 PM • Olympus Stylus... • Answered on May 19, 2010
Multiple error messages 3406 5f08 8234 5f10 om
4/23/2010 6:35:28 PM • Olympus Stylus... • Answered on Apr 23, 2010
When u turn on it beeps and goes to power off
Your problem may be due to a weak/worn out battery or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your battery may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
12/3/2009 5:24:55 PM • Olympus Stylus... • Answered on Dec 03, 2009
Olympus Stylus Verve / ?-mini Digital Camera Logo
49 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
David Shaub
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
lense keep closing cannot
  • Cameras
