SOURCE: how do i use the inverse log operation on the TI-84
The problem is simple. You're trying to get an [H+] concentration which is obviously going to have a value of some number times ten raised to a negative power. Therefore, you have to insert the negative value of the pH into the 10^(x). When you insert said negative number you will come out with the right answer.
i.e.
The pH of a sample of human blood was calculated to be 7.41. What is the [H+] concentration of the blood?
10^(-7.41) = [H+]
[H+] = 3.9 E-8
(the answer should only have two sig. figs because the pH has two digits after the decimal.
SOURCE: ERR:SINGULAR MAT when finding inverse of matrices
If a matrix has a determinant of 0, this error appears. If you get this error, your matrix doesn't have an inverse.
