Question about Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
Posted by asmarah_a on
k24674
  • Texas Instru... Master
  • 8,091 Answers
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
Posted on Sep 09, 2011
Change log base
The TI-30XA calculates logarithms to base e and base 10. You can calculate the log of x to any base b by calculating the logarithm of x and dividing it by the logarithm of b: log(x)/log(b) or ln(x)/ln(b).
Nov 29, 2013 | Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
How do you find the log of 9.01 using TI 30xA calculator?
To calculate the common (base 10) log of 9.01, press 9 . 0 1 LOG =
To calculate the natural (base 3) log of 9.01, press 9 . 0 1 LN =
Both the LOG and LN keys are on the top row of the keyboard.
May 09, 2011 | Texas Instruments TI-30XA Calculator
HOW DO I TYPE IN LOG BASE 3 OF 18 IN MY TI 30X
You can calculate the log to any base by using the relationship logb(x) = log(x)/log(b) = ln(x)/ln(b). In words, the base-b logarithm of x is the logarithm of x divided by the logarithm of b.
So, to calculate the log base 3 of 18, press
1 8 LOG / 3 LOG =
or
1 8 LN / 3 LN =
Mar 06, 2011 | Texas Instruments TI-30XA Calculator
I need to use a TI 30Xa to evaluate a Logarithm Log5 1/625 Not sure how to use the TI to do Log5
Use the relation log5(x) = log(x) / log(5) = ln(x) / ln(5)
LOG ( 1 / 625 ) / LOG 5 =
or
LN ( 1 / 625 ) / LN 5 =
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
Antilog in chemistry problem
pH is minus (log to base 10) of the hydrogen ion activity of an aqueous solution, or (log to base 10) of (1/hydrogen ion activity)
To get the inverse log, i.e the hydrogen ion activity corresponding to a specified pH, simply enter the pH value and press
2nd
LOG
1/x
Answer 0.001
Apr 22, 2008 | Texas Instruments TI-30XA Calculator
TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Dec 10, 2007 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
306 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Scoee Scoffer
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
