SOURCE: HP OFFICEJET 7410 "NO SCAN OPTION"
1.open the HP Director/Solution Center 2.click on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
SOURCE: Printer is not working after changing the router
Hi Nagureddi,
Please click on the web link given below and perfrom the steps as given in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00805046&cc=us&lc=en&dlc=en&product=391194
Have a great day!
SOURCE: I have a J6400 all
If your router is set not to broadcast or has encryption enabled, you will first have to program the printer by software throught a USB cable, or at the panel on the printer. The printer manual should explain how.
If you need a copy of the manual or other support, it's at this link. Just select your exact printer model and operating system first.
J6400 Printers Support
SOURCE: Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
