Question about NetGear CG814WG 54 MBPS WIRELESS CABLE MODEM GATEWAY Router
How to connect hp officejet 4620 to my netgear cg814wg v2
Trying to connect to my hp officejet 4620
stephen Adams
  • NetGear Master
  • 2,219 Answers
First connect it via USB to a computer and set it up so it works over the cable.
Then re-install it to be wireless, putting in the router requirements.
Then under instructions unplug the router.
It should then be set up to run wirelessly.
Posted on Mar 08, 2015
5 Related Answers
Anonymous
  • 30 Answers
SOURCE: how do I findmy wep key?
Hello ffoeg66off, My friend has the same make of router, If you can't find your wep key, are you sure it has one, not all routers have them, mine does, but my friend doesn't. If your Nintendo DS askes for a wep key like mine did, try to find a long conbination of letters and numbers, if it doesn't, you dont need one!
Posted on Dec 29, 2007
Anonymous
  • 34 Answers
SOURCE: connecting XP wireles Client to Netgear MR814 v2
Please see if this things are done:
  1. Power on your wireless device - now a days, laptop have a manual switch aside from software-base application. It usaully a tiny switch witch is mostly located at the edge of your laptop.
  2. You might have entered an invalid key - use notepad to enter your security keys then cut and paste it on your application setup.
  3. Reinstallation of your device driver.
  4. Your router networking is not broadcast so do it manually by supplying SSID and security keys on the setup menu.
If this thing are done correctly, better see your supplier.
If you think this things are helpful, please rate me.
regards,
-engrkoiled-
Posted on Mar 27, 2009
Anonymous
  • 1383 Answers
SOURCE: Netgear vpn824 v2 won't reset; wired works; wireless not
accessm your router with following link
http://192.168.1.1 or
http://192.168.0.1
then enter user name as "admin" and password as blank or "password"
then go to wi fi security enabled wireless.
Posted on Jul 15, 2009
Anonymous
  • 854 Answers
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username ([email protected]) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 13, 2009
anandg27
Anand Gupta
  • 1272 Answers
SOURCE: in need of drivers for netgear cg814wg v.2
Hey buddy, this is a plug and play modem gateway and does not require drivers for its configuration. If this modem was provided to you by your ISP then please contact them for its configuration as these modems are ISP specific like Timewarner, comcast, cox. If not, then let me know so that I can assist you further.
Posted on Oct 12, 2009
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP Officejet 4620
Use a go/nogo tester to check the on switch. I suspect it needs replacing.
Mar 20, 2014 | HP Officejet 4620 Wireless Multifunction...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
[email protected]
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Password for Netgear CG814WG router?
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Dec 07, 2011 | NetGear Computers & Internet
I need to open 6 gaming ports to access Xbox 360 live. How do I do this
here is a complete guide to doing it here
http://portforward.com/english/routers/port_forwarding/Netgear/CG814WG/Xbox_Live_360.htm
Feb 20, 2011 | NetGear CG814WG 54 MBPS WIRELESS CABLE...
HP OfficeJet 8500 Printer not printing from Wireless Laptop as it did before as the Wireless Antenna was replaced with a new one since it failed. the new one is: Netgear WNR2000 V2 and tech support by...
It looks like you are talking about 3 devices: laptop, router, and printer. Assuming you can connect to the router and Internet with your laptop indicates the router is OK with the new antenna. So the problem is with the printer. My suggestion is to remove or delete the printer from your laptop. I would then reset the printer and connect it wirelessly to the router again. Then add the printer to your laptop.
Jan 03, 2018 | HP Office Equipment & Supplies
NetGear CG814WG 54 MBPS WIRELESS CABLE MODEM GATEWAY Router Logo
137 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
