Question about Tablets & eReaders
Why does it keep loosing Wi-Fi connection? - Tablets & eReaders
Posted by Bobby Ingram on
Claude Kayser
    Top Expert:
  • Tablets & eR... Master
  • 9,098 Answers
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
Posted on Jan 04, 2016
Why will my wifi not turn on?
Hi Michelle, try turning your tablet off then on.... If still no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 18, 2016 | Lenovo IdeaTab A2109
My tablet keeps saying Avoided poor internet connection every time i try to connect and ive tried everything reseting, turning on/off the wifi everything and it still wont work
If other devices work ok on the same Wi-fi, then the tablet should, as long as it's near the Wi-fi router but not too close to it.
Mar 24, 2015 | Nextbook Next3 tablet
Irulu 7" tablet keeps disconnecting from internet. It's connect for a minute or so and then just drops. Just received replacements for 2 in the mail yesterday. No connection problems with old ones.
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Feb 07, 2015 | Tablets & eReaders
Ok I asked the question three days ago why can I get on a free wifi connection with my phone but not my tablet
The free Wi Fi router may have run out of IP leases on its DHCP server just when you were trying to connect the tablet. If the leases are as an example say one week long then if lots of people connect to the free wi fi they get a lease for one week. So if the device comes back within the week it already has an IP address assigned to it and works. If a new device comes along it has to ask the DHCP server via the WI FI to assign it an IP address. If all available IP addresses are leased from the WI FI router the device will not get assigned an ip address. Would suggest trying to connect the Tablet on another Wi FI system to test it works.
I had this happen on my mobile phone when I was in Surfers Paradise in a Coffee shop and suspected the lease time on the WI FI router was too long for the amount of short term customers using the coffee shop. (the staff had no idea on why the Wi FI was not working so it would have been pointless to try and explain this concept to them and how to change the lease time on the dhcp server) Also there is a limit to the simultaneous number of users on a Wi Fi frequency on one access point . Unless the WI FI uses multiple WI FI access points.
Jan 27, 2015 | Mach Speed Trio Stealth G2 Tablet -...
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
My new zte v9 wont connect to the Internet
you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
Dec 02, 2012 | ZTE V9 Smartpad Android Internet Tablet
Tablets & eReaders Logo
119 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
